Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Lumpy drum noise
My drum seems to be off it's trueness like a bad tire, the front of the drum has alot of play making a thud noise
  • 1 more comment
  • cyndia Apr 26, 2008
    dryer makes a loud thug noise and is cracked, inside (like a stress crack)
  • ridrime Jun 09, 2008
    My Neprune dryer also has a loud thumping noise and a cracked drum. How this possible?
  • llmjkane May 14, 2009
    My dryer makes a loud thumping noise and then I found that the drum has cracked.
I have a gas dryer same model- look at the front of the drum at the seam. Mine is cracked and causes a loud thumping noise
Posted on Mar 27, 2008
Did you remove the shipping bolts from the back of the machine
Posted on Mar 26, 2008
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
Steering wheel starts to vibrate at 55 mph vibration goes away at 65 mph or if i maintain 55 to 65 mph while applying pressure to the brake pedal vibration stops. also when drive over a curb, (e.g.backing...
i would suspect somewhere in your front end you have a compliance bushing with excessive movement. these cars front ends depend heavily on these style bushings, and as they wear you can start to see tire wear patterns, looseness in steering, and high speed vibration. make sure you have the front end inspected by a shop that is familier with these types of cars. good luck!
Apr 10, 2010 | BMW 535 Cars & Trucks
MAKING A
Hello
Some dryers use a motor driven drum.If there is a piece of belt missing this could cause a thud noise.
Also the drum rests in rollers,if a roller is missing or worn this could also be your noise.
Mar 21, 2010 | Maytag Dryers
Making thud thud thud noise when spinning. Has been installed for 3 years and started noise a week ago.
Possibly a drum mounting broken, remove the lid and grab hold of the drum and see if it moves up and down or sideways by hand, if it does one of the mountings has broken
Aug 24, 2009 | Roper Washing Machines
I noticed a louder engine sound at approx 45 mph, like a humming or aceleration sound, I had the driver's side wheel bearing replaced to the tune of approx $300 but the sound still remains (the repair guy...
Chevrolet has a common problem with integral hub and wheel bearings wearing due to exessive use or lack of lubrication, the balls or rollers and races become pitted ,scored or just plain damaged which will infact cause a loud humming or growling noise. I have had some humm at about the same speed but usually they will start to make noise at any speed. I would have to hear the noise to be sure cause there are many things to cause a humming noise like odd tire wear, bad idler pully bearings, e.t.c. the tires should be lifted checked for excessive play in the bearing. Take tire off depress brake piston in just enough secure brake rotor use stethoscope spin hub while listening. maybe he replaced wrong side seen that alot, seen tire noise mistaken for bad bearing to if struts or shocks are worn can cause tires to be choppy. I would recommend taken back 300 dollars is alot of money to not fix your problem.
Jul 15, 2009 | 2005 Chevrolet Equinox
91 ford explorer making bad noises in the front by the front tire
BY THE SOUNDS OF IT ONE OF YOUR WHEEL BEARINGS HAS GONE BAD. WHAT I WOULD DO IS JACK UP THE FRONT END AND CHECK FOR PLAY IN THE WHEELS MOVE BACK AND FORTH TOP TO BOTTOM SIDE TO SIDE. CHANCES ARE YOU WILL FIND ONE OF THOSE WHEELS HAS ALOT OF PLAY IN IT. IF THAT IS THE CASE YOU WILL WANT TO REPLACE THE INNER AND OUTTER WHEEL BEARING AND THE WHEEL SEAL. TRY THAT GOOD LUCK AND HOPETHIS HELPED.
Jun 21, 2009 | 1991 Ford Explorer
Dryer makes a lot of noise and sometime stops
yes the rollers can wear down and make alot of noise I believe there are 2 on yours.
Jan 13, 2009 | Amana Dryers
1990 Lexus LS 400 Right Front Suspention Thud Noise
most probably a torn lower suspension arm rubber bush that would not show up if the car was on a 4 post hoist
there is a problem there as the noise would not be evident if there was nothing wrong
different tire pressures will give different noise when hit with a tire lever ( a trick used by truck drivers to check for flat/ under inflated tires
good tire solid sound
low pressure tire a dull sound
Apr 23, 2017 | 1990 Lexus LS 400
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
397 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
