Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
When you trying to scan picture &
When you trying to scan picture & cocuments&print & edit picturns from the p c it will code error 2075
  • 64 Answers
Before you do the above solution from Bala10Kri (that doesn't tell you what to replace them with) or probably doesn't even know that the scanner drivers from the printer is twain drivers (Microsoft scanner drivers). Try the below and I bet you will come right.
To resolve this error code:
  1. Close Home Center Software.
  2. Go to Start>Computer.
  3. Show hidden files and folders:
    • Select Tools>Folder Options.
      NOTE: If the Tools menu is not available on the menu bar, press the <Alt> key on the keyboard, and then a menu bar with the Tools menu will appear.
    • Select the View tab.
    • In the Advanced Settings, select Show hidden files or folders.
    • Select Apply.
    • Click OK.
  4. Navigate to:
    • 32-bit systems - C:>Users\(username)\AppData\Local\VirtualStore\Program Files\Kodak\AiO\Center
    • 64-bit systems - C:>Users\(username)\AppData\Local\VirtualStore\Program Files (x86)\Kodak\AiO\Center
      NOTE: The username in the path above is the username you logged in with.
  5. Right-click AiOHomeCenter.exe.config and select delete to remove the file.
  6. Hide hidden files and folders:
    • In the Advanced Settings, select Do not show hidden files or folders.
    • Select Apply.
    • Click OK.
  7. Run Home Center Software to run as an administrator:
    • Right-click the Home Center icon, then select properties.
    • Select the Run this program as an administrator check box in the compatibility mode.
    • Click OK.
  8. Open Home Center Software and print or scan a job.
Posted on May 07, 2010
  • Dazzy D May 07, 2010
    To elaborate on my above statement because some people battle with step 4
    What I mean is: Click on start and select computer. Then go into your C drive then go into Users go into what ever your username is then go into AppData then go into Local then go into VirtualStore then go into Program Files then go into Kodak then go into AiO then finally go into Center.
    Hope this helps...
  • 31 Answers
Replace the scanner drivers
Posted on May 06, 2010
Ricoh 2075 error code sc101
Ricoh MP 2075 SC error 101. Found that the Exposure Lamp would stay on after reaching home position and this fault would appear. Found the solution was to replace the IPU PWB
Apr 22, 2014 | Office Equipment & Supplies
Aficio 2075 sc 990
Most of the time is trash on the network.
Also SC990 sometimes occurs if the signal timing during scanning and printing causes a delay in the process.
There is a firmware that fix this error. You need to download it (if you know how to do it of course).
Apr 11, 2011 | Ricoh Aficio 450 Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Error code 2075 keeps coming up when I try to scan a document to desk top what do I do?
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then select find target.
    • Select Apply.
    • Click OK.
    • Click OK.
Jun 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting error 2075 when i try to use the kodak aio Home Center
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then on the general tab select find target.
    • Select Apply.
    • Click OK.
    • Click OK.
May 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
All of a sudden my MP500 gives an error code
If the carriage will come out of the right corner, you need to look inside and see if there's a paper scrap or anything blocking the purge assembly. The purge is the unit that cleans the printhead, and that error says it's not moving properly. If nothing is stuck in there, you will need to have the purge assembly replaced.
Dec 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have an error code 1-2070 the printer print off
Go to kodak website and download latest drivers for Scanner. It will/should also tell you how to repair pictures.
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Scanner not working
Hi Jkey !
As per the information you have provided, I understand that you are receiving an error "No scan option refer to the documentation" on the printer, when you try to print from the front panel of the printer (I mean from the printer's side).
However, plz provide me the proper error message so that I can assist you in the best possible way. If you are unable to scan from the printer's side, then try to scan from the computer and check if it is working or not. It should work when you try to scan from the computer, if not there may be a communication issue between the two devices.
To check the communication perform the below steps:
IF the printer is connected via USB cable, then perform below steps:
Useful scripts For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are able to scan fine using the above steps, please write back to me along with the exact error message.
With Regards
Mike.
Jun 27, 2009 | HP Photosmart 2575 All-In-One Printer,...
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error response on hp psc 2355 AllinOne printer,scanner, copier
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, please let me know.
Thank you so much. I Remain
adonscott
HP TECH
Jun 18, 2008 | HP PSC 2355 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
282 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
