Question about Singer 7444 Mechanical Sewing Machine
7444 Mechanical Sewing Machine: i have to sew a stay stitch, i am not sure what to...
I have to sew a stay stitch i am not sure what to set my tension at on my new machine which is a singer precision 7444
    New Friend:
  • 184 Answers
You should not need to change the tension for a stay stitch.
Posted on May 07, 2010
Singer 7444
Read the instruction book or take to professional,
Jan 19, 2014 | Singer 7444 Mechanical Sewing Machine
When you stitch a piece of cloth, the stitching appears to be loose, resulting in a very untidy stitch.please help immediately.i didnt get a booklet with my sewing machine
Firstly you can download a manual from the Singer website, link is
http://www.singerco.com/accessories/instruction-manuals, type in "W750" and click search.
Once youve got the manual downloaded, I'd suggest you print it out and get it bound in covers so it can stay with the machine.
Then trouble shoot the tension, this sounds to me like you've got insufficient or no tension on either top, bottom or both threads. You need to revise the threading up and make sure you always thread up the top with the pressure foot raised so the thread properly seats into the tension discs. Set top tension on the normal mark between 3 and 4 and make sure when you load the bobbin into the bobbin holder, that the thread gets clicked into the tension spring completely.
Now test sew again, and tighten up the top tension a fraction if it shows on the underside. You can't adjust the bobbin tension on these machines or at least the manual doesn't show any adjustment, just says to adjust the top thread tension.
As a rule of thumb, change your sewing machine's needle for each new sewing project too as this will help with stitching quality.
If you can't get it looking any better consider taking the machine back to the shop (if its fairly new) and getting it checked.
If you are planning to sew lots of things, you may want to consider buying a higher level quality machine than this one, it is an entry level machine and there is huge variation in stitching quality between the cheaper models and the higher end quality ones. Just depends on your sewing needs and desires I guess as to whether its worth investing more $$.
Sep 21, 2011 | White Sewing W750 Mechanical Sewing...
My singer 7444 makes beeping sounds when operated, the machine fails to start.
Ensure that your stitch width and your spacing are set to a green-light setting. Also, ensure that your stitch wheel will operate(It will lock in the case of a jam.), and check to see that the stitch you have selected is compatible with the kit load you have onboard, i.e. for buttonholing, ensure you have the automatic buttonhole foot attached and the buttonhole lever down. In all other stitches, ensure the buttonhole lever is in the full up position.
The 7444 Precision is a "Smart" machine, and will not allow you to attempt a stitch that simply will not work with the wrong stitch spacing and width settings applied. Move the sliders slowly until each one lights up green, or at least does not light up yellow/orange at all.
Feb 08, 2010 | Singer 7444 Mechanical Sewing Machine
How can I use this machine as a MERROW machine ?
For best results, use Maxi-Lock cone thread.
Remove the left needle.
Slide the stitch forming finger towards you, away from where the stitch forms.
Set the stitch length to around 1.
Set the needle tension 4 or 5.
Set the upper looper tension at 4.
Set the lower looper tension at 7.
Adjust the stitch width, if needed.
Jan 24, 2010 | Juki MO-644D Mechanical Sewing Machine
The thresd gets knotted and it won't stitch
Rethread your machine
Make sure your cotton runs through the two tension plates
Check that your top tension is set on 5
Make sure your bobbin case is threaded correctly
Lastly, make sure there is no cotton stuck between your top tension's plates(take a long needle and remove any fluff)
Sep 14, 2009 | Singer 6038 Mechanical Sewing Machine
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Tension settings for a rolled edge
3 Needle
1-3 Upper
7-9 Lower
1-2 Stitch length
Tension .7
Stitch finger 7
Dec 10, 2008 | White Sewing Superlock 1934D Mechanical...
MO -634 mechanical sewing machine problem
What does "doesnt have good sewing results" mean? Is the stitch loose? Does it skip stitches? is the tension balance off?
The serger "It doesnt sew right" rule of thumb: replace your needles, make sure they are inserted all the way into the clamp (one will be hight then the other) and orientated properly (eg. flat to the back), COMPLETELY unthread machine, re-thread!!!! re-thread!!!, check for proper threading (make sure thread is in tension discs if possible), change your thread.
Improper threading is the #1 problem causer. I cant stress it enough. Rethread Rethread Rethread!
Dec 13, 2007 | Juki MO-644D Mechanical Sewing Machine
Singer 7444 Mechanical Sewing Machine Logo
188 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
