Question about Nintendo Super NES Console
Super nintendo trouble
I have a snes system, and all the power and stuff works. but when i plug it all in, and turn it on with a game in the only picture shown on my tv is red and black stripes, no game at all. please help
Sounds like the game is dirty, much like the original NES clean the game points, then try to clean the system points too.
Posted on May 17, 2008
Ineed help as well lol same thing but just a black screen Ive been searching for a sned and just got it today. and blah! Help someone please.
Posted on May 04, 2008
Im having a similar problem except my lines are black and grey with a buzzing sound..... i need help as well
Posted on Apr 25, 2008
My nintendo 64 game pack will not fit into the slot of the retoduo
YOU CAN NOT PUT NINTENDO 64 GAMES INTO SNES or NES SLOTS. The retro duo is snes (super nintendo entertainment system) and nes (nintendo entertainment system) only there is not spot for the nintendo 64.
Dec 29, 2014 | Nintendo Video Game Consoles & Games
When i plug my snes to my tv it wont work :/ i plug the cable to tv and put the snes on chan3 then i go on channel 3 with my tv and it show me a black screen ,sometime i hear 2 sec of the game music :/
Hi pikapike,
I see you are going back to the 90's with your Super Nintendo. Firstly I do not know how you can "put the snes on chan 3". If I am correct, all super nintendo cables to the TV are RV coloured ones. therefore once it is plugged into the TV, you will ant the A/V channel? which usually has a separate button.
Secondly if what you say that you get a flash/glimpse of the game, then check the system of your TV. Is it PAL (Europe, Aus, NZ, etc) or NTSC (U.S.) Hopefully you can change the TV settings to match your game console!
Hope this helps,
kamacosmic
Feb 19, 2011 | Video Game Consoles & Games
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
SNES no power (light on for 1/2 second) Fuse good
Well I think that the fuse is blown on the system. 1.5amp pico fuse.
Oct 16, 2009 | Nintendo Super NES Console
My SNES won't turn on.
The system fuse is blown on your SNES. This is sometimes caused by pulling the game out or putting a game in without turning the power off.
If you don't have any soldering skills, it's best to let professionals replace the fuse. Search Google for part SNSPT010 if you can solder a new fuse in.
Sep 14, 2009 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
BROKEN adapter PLUG IN ON SUPER NINTENDO
The dc jack where you plug in the ac adaptor is worn out which is why it is chipping and also why you can't make a good enough connection for the ac adaptor so you can turn on the Super Nintendo.
What needs to happen is your SNES needs to have the old dc jack taken off and a new one soldered on.
If you can find another broken SNES that has a good working dc jack then take if off of that one and solder it onto yours and your SNES will work like new.
May 28, 2009 | Nintendo Super NES Console
SNES not working with Street Fighter Alpha 2 (graphic chip)
I'm not sure what a pin card is, but my best guess is that the game is dirty?
Apr 29, 2009 | Nintendo Super NES Console
COnsole trouble for SNES
The old school gamer. :-)  Love it.  The plow in the bottom of the game.  Then try.  This normally works :-)
Oct 22, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
371 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
