Question about Dryers
Drum not rotating true
I have opened up the front and made sure things were safe to turn on and watched the drum turn, it has a lump to the rotation and I noticed the drum was not a true circle spin it seems to be out of of balance, when it started this problem it sounded like a blanket that was knotted up and thuding against the drum
  • Tim Buckley Dec 26, 2008
    as the drum rotates, it sounds like there is a shoe thumping around in there and the drum has a little upwards movment as it gets to the same point on it's revolution.
  • 185 Answers
Check the rollers
Posted on Mar 27, 2008
Drums won't rotate
Open the front, leave it open. Open the top, pull out your drum. Put the drum back in, close the top. Close the front, let it rotate, and power off. Power back on and your drums should rotate automatically.
May 21, 2012 | Konica Minolta Magicolor 1600W Printer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
DRUM IS NOT ROTATING, BLOWER IS WORKING AND IS PRODUCING HEAT could i have blown a belt?
Try this first:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn, sometimes motors get dead zones in them and this will rotate it out of the zone if that is your problem.
If that did not work then chances are that you have a broken belt.
If you have a front loading machine:
If you remove the front of the dryer, it will expose the drum and the belt, if you remove the drum it will expose the drum rollers, motor, and idler pulley.
I hope this helps
Oct 04, 2009 | Whirlpool Dryers
HOW TO INSTALL THE DRUM UNIT for ir2230 copier
Open front cover of copier. Rotate lever (I think it's blue) to lower transfer/transport assembly. Rotate Developer/Toner assembly handle to move assembly away from drum unit. There is either a phillips screw or a plastic gripped screw that needs to be removed. Then, carefully, pull the drum unit 2/3 of the way out. At this point, the back half of the unit needs to be supported while pulling the rest of the way out. Open new drum unit. Remove all packing materials with red tag attatched...especially black paper covering new drum surface. The new Drum Unit has guides on top that line up with guides in the machine....carefully insert unit in copier until it seats FULLY. Reinstall screw to front of unit. Rotate Developer/Toner Assembly lever to cam back against Drum Unit. Rotate Transfer/Transport Assembly lever to lift assembly upward and latch. Close front cover.
Jun 13, 2009 | Canon IMAGERUNNER 2230 Copier
NOISE DRUM ROTATES
there are 2 screws holding the loewr panel on the unut, you can remove the panel and watch it operate to pinpoin the"noise" most likely cause is a roller on rear wall, or perhaps a faulty front set of glides( the drum sits onthem)
Mar 08, 2009 | Maytag SDG3606A Gas Dryer
Gringing noise and says to replace drum. Replaced drum and still grinds and says drum needs replaced
look at front of machine where your received faxes come out. you will see a couple of rollers there. unplug fax, and while watching the rollers, plug in and see if they turn when machine starts rotating. if they don't, you have a broken heat roller gear. another thing can cause this is a bound up toner cartridge. try another if rollers are turning. last but not least, your old drum possibly damaged your drum drive gears.
good luck,
razors
Feb 19, 2009 | Brother IntelliFAX 2800 Laser Fax
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
Maytag MDE6000AYQ Dryer
ritz, it could be the motor, but eliminate these other things first. You want to make sure you don't have a drum roller in back binding, I see a lot of this on Maytags. Another would be the blower wheel, it could be binding or have something stuck in it. The blower wheel will be in front. You will have to remove the door, remove the screws holding the hinges in, the door will lift up and off. Then the spacers on the other side. Now the front panel will pull out and off. Here you can get a look at the blower wheel, and rear rollers. Just hang the door back on and close it to run it. You may have to remove the front drum support and remove the tumbler to get into it further if necessary. Catriver.
Jan 05, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
109 people viewed this question
Top Dryers Experts
