Question about Maytag Neptune FAV6800AW Top Load Washer
Need to ask about Maytag 7600
On the washing cycle the machine has a whining sound. I suppose it could be better said when it's agitating the clothes. Does this mean I should replace the belts, motor or something is more simple than that. Thank you Master.
Mike email [email protected] [email protected]
    Guru:
  • 462 Answers
You should reove the belt and check for roughness in the way the water pump bearings "feel". If they are tighter one way than the other you may have "string" or something wound inside the pump or bad bearings. also do thew same test on the motor it should spin free both directions also. And check the "thrust" the in and out play on both shafts. Lastly check the transmisssion mAIN DRIVE PULLY for true and streightness a warped or bent pulley could cause a noise problem but usually will do the same noise in either direction.
Posted on Mar 29, 2008
SOURCE:
Where is the pressure switch hose on Maytag Centennial MVWC6ESWW1 located?
Pressure switchnhoses are usually located off the bottom or lower half of the drum. It willnormally be about women diameter hose that connects to a plastic box with a few wires at one end, and the drum housing at the other
Jan 16, 2018 | Maytag Washing Machines
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer never stops running, goes from 1 cycle to the next
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible.
If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
