Question about Brother CS6000i Computerized Sewing Machine
Threading and thread breaks
Just bought this.
I don't know the correct tention for simple sewing. Everytime I try..the thread breaks! Then it shudders..:(
Am about to return it!
  • 106 Answers
The shudder bothers me!!
Would suggest take it back before you start messing with it or letting a sewing machine tech near it. Last thing you want to do is run the risk of voiding the warranty.
Best of luck
Rob
Posted on Mar 28, 2008
SOURCE:
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
I have multiple threads coming out the bobin space and making a mess of the back side.
called bird nesting and is a result of too loose a needle thread tension
if you use an automatic tensioner or using the numbers
and you still have a problem, the correct tension is a resistance to you pulling the thread prior to threading the needle
Feb 08, 2018 | Sewing Machines
Model 230. Why is it losing the thread at the needle everytime I sew?
The thread sounds like it is not running freely so the upper tension is either too tight or blocked by lint.
If neither of these solutions work then try changing your needle as a blunt or wrong needle can also be a cause
Nov 29, 2015 | Consew Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
How to stop thread from breaking in an older morse sewing machine
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 14, 2012 | Sewing Machines
I have an Elna xe35, everytime I use it, the thread Jams underneath, how do I stop this?
try changing the needle--normally flat side goes to the back of the machine
also make the needle & thread will work for the fabric being sewed
make sure the bobbin is turned the right way & inserted correctly in the bobbin case
make sure that the thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for loose thread & lint
Apr 02, 2012 | Sewing Machines
Singer Simple `when not threaded runs forward and backwards,,,, `when threaded,,,,moves forward for an inch,,,and then looping clogs the bobbin area,,,it appears as one inch loops under fabric,,,have...
Try this test, with the presser foot down, pull on the top thread, it should feed smoothly, now lower the presser foot, the thread should barely move, when pulled. This sometimes seats the thread in the tension discs. Hope it helps you.
Nov 15, 2010 | Singer Featherweight II 117
Sew Cute SC20 Mechanical Sewing Machine: how to thread sew cute machine ...
Place the origin bobbin thread so the thread is coming up (clockwise) extend to the thread tention, to the top thread holder, then down through the arm and then through the bottom thread holder, through the square thread guide above the needle, then through the needle, front to back. Check out a picture on ebay or amazon. That could help you visualize it.
If you are having trouble with the thread breaking, try changing the thread on the bobbins. The thread that comes with the machine is poor quality and jams & breaks. If you still have trouble, and might suspect the needle is dull or bent. Change it, it makes a difference. I had the thread problem with the machine right out of the box. Changed it and it works great!
May 17, 2010 | White Sewing Sew Cute SC20 Mechanical...
My thread keeps breaking. I got this machine
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. [email protected]
May 10, 2010 | Sewing Machines
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
93 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
