Question about Panasonic KX-T7730 Corded Phone
KX-T7730 Corded Phone: WHEN THERE IS AN INTERNAL INTERCOM ACTIVATED TO AN...
When there is an internal intercom activated to an empty desk how do we intercept to answer the initiating party
  • Panasonic Master
  • 2,460 Answers
Make sure the Auto Answer button is not lit on the empty desk phone, then you could use either 40 to answer all calls, or 4+ the extension number to absolutely answer that phone.
Posted on May 06, 2010
How to pick up a internal call from colleague extension?
Depending on the system the phone is connected to, you can dial 40 on the intercom or 4+1xx (the intercomed extension) to pick up the call.
40 will pick up anything ringing in your group, so if you want to be sure it's only going to answer your colleague's call, use the 41xx code.
If the code doesn't work, check out your user's guide for directed call pickup.
Carl
Dec 31, 2012 | Panasonic KX-T7730 Corded Phone
I have a Panasonic Keyphone Model: KX-T7750, having problem with alert of intercom/incoming calls. No ring tone but with flash light and intercom light on. May I know how to fix this. Thank you!
Calls are signalled in two ways. First, check the Ringer switch on the left side of the phone. It's a 3 position switch OFF/LO/HI. If the outside lines are blinking the MESSAGE light, then the ringer is probably turned off. If your intercom calls are toning but not ringing, you may have the AUTO ANS light lit. Press it until it's off and intercom calls will either start ringing or send an audible tone.
If it tones, then you have a programming problem where intercom calls are set to tone instead of ring. That's corrected in system programming.
Carl
Apr 25, 2011 | Panasonic KX-T7730 Corded Phone
I have a panasonic kx-t7730 phone. A techie set up call forwarding from the phone to another extension, and now I can't remove it. Can you help?
From the intercom, dial 7100 or 710#. Call forward codes are set via 71x and the extension plus #.
This is the TA series code set. The bigger systems have 710x codes.
Carl
Mar 29, 2011 | Panasonic KX-T7730 Corded Phone
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
How can i active or desactive the FWD/DND in the model. KXT7730?
it really depends on your phone system
but the possibilities are:
1) "INTERCOM"
2) *710
3a) 0 to deavtivate
3b) 5 to set to busy/no answer
4) put the number you want to fwd to then "#" *confirmation tone*
or
1) "INTERCOM"
2) 710
3a) 0 to deavtivate
4) put the extension number you want to fwd to *confirmation tone* (extension number only)
Jan 03, 2011 | Panasonic KX-T7730 Corded Phone
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Carl
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
Jun 11, 2009 | Panasonic KX-T7453 Corded Phone
KX-T7730
have you tried calling from another phone not connected to your main box? hold music will not work at intercom call.
Jul 28, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
398 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
