Question about Philips 150MT 15" LCD Monitor
150MT 15" LCD Monitor: cpu munitor league but the picture is not displaye...
Cpu munitor league but the picture is not displayed to the screen all black what can be?
A nieed programe flashm for philips 150mt
Posted on Sep 01, 2011
Soon as ssoon as i turn on the computer the monitor flashes the the logon screen; two seconds later the display is gone. The monitor indicates that it is still on but no picture. I turn the monitor off...
Here the monitor does not have any problem.Initially test monitor by removing the monitor cable from the cpu.
you can see small boxes moving in the screen this ensures your monitor is ok
Here he problem is with Ram in the cpu .Just remove the ram and clean the ram slot and ram and then fix it tt will work fine
May 21, 2010 | Computers & Internet
My acer lcd monitor has no display and the power button keeps blinking. is there a way to fix this myself.
that may be the problem of cpu disconnect the signal cable and observe the massage that "no signal check the signal cable "if that massege appears then monitor is ok problem lies in the cpu
Mar 15, 2010 | Acer AL1511 15" LCD Monitor
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Monitor light goes blinking it does not display .
ok
open your cpu plate then refix your ram after clean it.
also check keybord num lock is on and off
then when u power up press F8 key then go to enable cga mode.then set in display properteis screen resolution to 1024*768
Jan 19, 2009 | Dell E153FP 15" LCD Monitor
Sony Screen Colors
it may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Oct 25, 2008 | Computers & Internet
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Philips lcd monitor!!
invest in a better monitor. Philip has never put out a good product.
Nov 14, 2007 | Philips 170B4MG 17" LCD Monitor
Philips 150MT 15" LCD Monitor Logo
134 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
