Question about Midway Home Entertainment Rise & Fall: Civilizations At War for Windows
Rise & Fall: Civilizations At War™ for Windows: i am havin troubles installing and running a game ...
I am havin troubles installing and running a game called rise and fall civilizations at war... After a few trys i fugured out my origanal problems but now when i am finished downloading the game a window comes up saying i need to restart the computer before the game will work. When reset the comp comes back on with a screen that says there is a start up problem... Then it runs a test (at first i thought i had some viris but i dont think so) when it gets back to windows desk top the game is no longer is installed its like i never downloaded it at all
4 Suggested Answers
Magical Ink
  • 133 Answers
SOURCE: Cant install Rise and Fall
Hi there
Welcome to fixya
yes thee have been numurous complaints on this exactsituition,need be windows seven is supposed to be a machine of its own ,there might be a few glitches as to when windows seven eas designed so not many game swould interact properly with the sytem as some games are are made for certain pc's its a huge problem i shal contact the company to find out what the possible causes could be and then post it as a tip on my profile for all to view with the do's and dont's
pleae remember to rate this solution
thank you for using fixya
Regards
Magical ink
Posted on Aug 29, 2010
SOURCE: my mouse will not move on rise and fall
Looks like, the main problem is the mouse driver.. I've got Razor Abyssus with 1000hz and 3500dpi and it stands still.. but I do remember, when I've played Rise and Fall a little time ago, with my different mouse
Posted on Jun 07, 2011
  • 216 Answers
SOURCE: I'm trying to play rise
Depending on what operating system you have, it might legitimately be a compatibility problem with the OS. For example, if it's a 64 bit game and you're running it on a 32 bit platform (unlikely), or if the game was made for XP and you're playing it on Vista or 7.
One of the possible solutions (for the XP and Vista/7 problem, or basically any problem similar) is to right click on the .exe for the game and change it to compatibility mode. Go to My Computer>C:>Program Files (or Program Files (x86) in Vista/7)>Midway>Rise & Fall etc etc...It might not exactly be that directory, so in order to find it you can find its entry in the Start menu and right click on it, and go to properties. In the resulting menu you should see "Shortcut Target" or something to that effect that tells you the directory in which the game is located.
Open that directory and find the executable for the game. It should have a little mini picture of the game and should be named the same as the title of the game. Right click on it and go to Properties, then go to Compatibility. Check the box "Run this program in compatibility mode" and select the operating system in the drop down box for which the game was designed (You can find it on the back of the box). Now try running the game, and it should work in theory.
Unfortunately, I've had no luck with compatibility mode. Another option that might or might not work (depending on the requirements of the game) is to run it on a virtual machine. You can download VirtualBox as a virtual machine emulator, then create a virtual machine with the desired operating system. You have to have access to a licensed copy of the target OS, however, so if you don't have one this probably won't be the best solution for you. Also, virtual machines have a bad habit of not being compatible with certain graphics engines, etc, so it might not work anyway...Just a thought.
Though I've never used it, Windows 7 (if that is your operating system) users can download something called "Windows XP Mode" which lets you run programs which were designed with XP on your windows 7 platform. I believe it's some form of virtualization that's done, but as I've never used it, unfortunately I can't give you any helpful advice as to how to install, set up, and run it. You can most likely find anything/everything you need online. If you have any specific questions let me know and I can do some research and see what I can find out. Best of luck!
Tj
Posted on Aug 09, 2011
Unable to locate file, the data path appears to be incorrect, pleas check your data path After i open the game
The game's installation seems to corrupt. Try re-running the game's setup file and - whenever possible - choose the 'Repair' option ...
Jun 27, 2014 | Midway Home Entertainment Rise & Fall:...
Robert E. Lee: Civil War Install Help
if that is an old version , it probably will never install or work in windows 7. they do not upgrade old games
Dec 10, 2017 | Sierra Robert E. Lee: Civil War General
Problem with Rise & Fall: Civilizations At War for Windows 7. how to open ebooklibrary.exe
To install and run "R&F Civilizations at War" in Windows 7:
1) Run the Setup file and install the game
2) Google and download "http://www.ausgamers.com/files/process/24085/rise-and-fall-civilizations-at-war-patch-v115-beta" and "http://www.star-force.com/support/sfdrvup.zip".
3) Install "Rise and Fall: Civilizations at War Patch v1.15 beta".
4) Run the game, let it install required libraries and then reboot.
5)Run sfdrvup.exe and update the protection driver. Reboot.
Now the game should run in Windows 7.
Jan 08, 2012 | Computers & Internet
I'm trying to play rise and fall civilizations at war but i tried to play it after installing it and an alert came up saying there was compatibilty problem. please help
Tj
Aug 09, 2011 | Midway Home Entertainment Rise & Fall:...
Cant install Rise and Fall Civilizations at war on windows 7 Says it cant find the directory to install or something never had this problem before and after reading some posts online it looks like im not...
Hi there
Welcome to fixya
Regards
Magical ink
Aug 28, 2010 | Midway Home Entertainment Rise & Fall:...
My mouse will not move on rise and fall civilizations at war but it will pick up signals like clicking
Feb 14, 2010 | Midway Home Entertainment Rise & Fall:...
Compatibility problem with rise and fall civilizations at war
get a vista patch off the internet and install to your directory, it will afterwards work, i had the same problem :)
Dec 13, 2009 | Midway Home Entertainment Rise & Fall:...
Rise and Fall, Civilizations at war
i thiink your gfx card does not support required version of pixel shader....google for ne hack of pixel shader for the game..
Aug 24, 2009 | Midway Home Entertainment Rise & Fall:...
Midway Home Entertainment Rise & Fall: Civilizations At War for Windows Logo
136 people viewed this question
Top Midway Home Entertainment Video Game Consoles & Games Experts
jasbo
jasbo
richie46
Han Jenny
Han Jenny
Level 1 Expert
Are you a Midway Home Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
