Question about Sorelle Dondola 85 Crib
Dondola 85 Crib: can you order a side rail and mattress support?...
Can you order a side rail and mattress support?
  • 340 Answers
Hello! This is Products America. We can service many different manufacturers, however we do not carry the hardware for this style. You may call C&T International at 201-531-1919. They have a website www.sorrellefurniture.com . Sorelle, C&T International, and Golden Baby are all the same. Hope that we helped you with your needs.
Products America
Posted on May 06, 2010
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
Oct 19, 2009 | Bonavita Peyton Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Bassett crib 50681505
yes in here.. you can see this site: thanks
bassett mattress reviews
Mar 22, 2009 | Bassett Cottage 3-in-1 Crib
Missing parts
E-mail Simmons customer service with the model number (located on the bottom of the crib) and they will send you the parts #s and how to order spare parts. customerservice@sjfdec.com
Feb 10, 2008 | Simmons Mattress EasySide Crib
Parts Source
Full-Size Wood Bed Rails
Model: 180080
Dec 15, 2007 | Simmons Mattress Crib 'n More
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Sorelle Dondola 85 Crib Logo
103 people viewed this question
Top Sorelle Baby Gear Experts
Jeff Turcotte
Jeff Turcotte
Brett Duxbury
Brett Duxbury
Tom Chichester
Are you a Sorelle Baby Gear Expert? Answer questions, earn points and help others
