Question about Pentax *ist D Digital Camera
Pentax istD won't take pictures
My camera won't take a picture, I tried to take photos and it flashes AV - - on the top display. No mode will work to take pictures.
  • hardcastle Apr 25, 2008
    My Pentax *istD also started flashing Av - - and will not trip. It will work if I take the lens off or when I push the lens to the camnera without twisting it into place. It leads me to think it is a connection problem in the camera. It is not the lens as I took it in and tried a new lens and the same thing happened. I was told it was not anything I was doing but a problem in the camera which would require it being sent in for repairs.
    -- Don
  • Anonymous Jan 26, 2009
    I also have the same problem. Does anyone have another solution or an explanation why this is heepening?
    Thanks.
    New Friend:
I have recently had a similar problem and had tried everything I could until I realised the camera will not trigger if you have it set to manual focus and a manual lens.
Posted on Nov 14, 2009
I found this which seems similar
http://www.pentaxuser.co.uk/forum/topic/ist-D--HELP-444/p-0#comm_2164
"I know this is late, but the issue sounds to me like the aperture ring is not on A. and if this is a manual lens then you have to set the mode to hyper-program mode and set it to work with "other than A" on aperture."
this was my issue, i never knew that has i bought the camera 2nd hand without a manual - your issue might be something else but it's worth posting just incase
Posted on Feb 08, 2009
SOURCE:
Stuck on av
It appears that you may be in AV mode. You can get your manual here: http://www.ricoh-imaging.co.jp/english/support/man-pdf/istdl.pdf
Apr 29, 2014 | Pentax *ist D Digital Camera
Pentax ist d keeps saying delete after each picture i take before picture is shown
You can try to reset camera settings to default from the menu.
And fimware update could help if the software causes the problem.
http://www.us.ricoh-imaging.com/support/download-details/417
SD card write protection lock also should be off.
Jul 27, 2013 | Pentax *ist D Digital Camera
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
Pentax istd built in flash goes off when taking picture but picture is underexposed but if I use a different flash in manual mode the camera works ok
What distance are the subjects when using the built-in flash?
The built-in flash is optimized for use between 0.7m (2.3ft) and 4m (13ft).
You could also try adjusting the ISO setting (higher ISO requires less light) or adjusting the EV value to a positive number to increase the exposure.
May 14, 2010 | Pentax *ist DL Digital Camera
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Feb 20, 2009 | Pentax *ist DL Digital Camera
Pentax istDS Digital Camera, How to set Custom White Balance in Auto Modes
Custom white balance can only be set in P, Tv, Av, or M modes. The auto modes are, well, automatic. They are all preconfigured and intended for ease of use not configurability.
Nov 08, 2008 | Pentax *ist DS Digital Camera
Pentax MZ-60
please do a firmware upgrade
tell us what happened
Sep 18, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Pentax K100 problem
Might be temporary lack of communication between lens and body - try cleaning the contacts on both gently with a lint-free cloth and a very little IPA.
Jul 17, 2017 | Pentax K100D Digital Camera
Flash problem
That is normal operation, if poped up, the flash fires rapidily in low light to assist the auto focus, on a plain white wall, it can't focus, see the manual on AUto Focus limitations.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax *ist D Digital Camera Logo
496 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
