Question about Milwaukee 4270-21 Compact Magnetic Drill Press
4270-21 Compact Magnetic Drill Press: mag base will not hold at all...
Mag base will not hold at all
  • 843 Answers
If I'm not mistaken, these drills use an electromagnet. Start by measuring the current when the magnet is switched on, but not the drill. If you don't have a current meter, just plug the drill plus an incandescent light into a long lightweight extension cord. You should see the light dim a little when you switch on the magnet. If the light doesn't dim, you just aren't getting power to the electromagnet, and it's probably a broken wire or a bad switch. If the tool has it's own fuse, I would think it would be for the drill only, not the electromagnet.
Posted on May 06, 2010
Wil el diff fit au ford
please correct your English here.
what car, ISUZU
what model?> and year.
is this an engine question?
or is this a heavy Isuzu TRUCK.? if yes what?
Jul 06, 2014 | Isuzu EVR Valve. mag,tics. mag,2 speed...
Where can i obtain a realistic 32-1200 manual for free? or what does cera and mag on the back of the mixer mean?
In reference to the question -
" what does cera and mag on the back of the mixer mean? "
these jacks are for the input of phonograph record cartridge signals.
Phonograph cartridges are of two types -
1. "Cera"mic (ceramic) cartridges generate their signal using a ceramic crystal which provides almost 1/2 a volt of current.
2. "Mag"netic (magnetic) cartridges generate a more accurate signal than a ceramic cartridge but the magnetic cartridge generates its signal using a moving-magnet mechanism (rather than a ceramic crystal) and the magnetic cartridge generates much less current than a ceramic cartridge, so its signal needs a lot more amplification than a ceramic crystal's output. So the two jacks on the back of the mixer provide different levels of amplification for the phono cartridges, less amplification for a ceramic cartridge and more amplification for a magnetic cartridge.
Since few people play phonograph records any more it is understandable that the public has little knowledge of the differences between ceramic and magnetic cartridges. But each have their own benefits and usually ceramic cartridges are cheaper than magnetic cartridges simply because it takes a lot more sophisticated manufacturing technology to make a magnetic cartridge, though magnetics are usually preferred over ceramics because of their more accurate generation of a signal from the wiggling groove in a phonograph record. But for those who can hear, the complete sound signal from a phonograph record is much preferred over the dead and dry sampled sound from a digital CD. And the old 1/4" reel-to-reel tape recordings are the highest sound quality of all because they are direct copies of the original magnetic tape masters with no digitizing at all. The fullness of their sound is astounding compared to any digitized signal..
A mag input is down at the mic level.
A ceramic input is almost up at the line level.
Jul 25, 2011 | Audio Players & Recorders
I have need operation, maintenance and parts manual for 4209-1 magnetic drill press
go to"milwaukeetool.com and type in your model number, you will also need the serial number to locate the information you requested. You might need to separate the tools and use the base and motor separately but it is there.
Jul 21, 2011 | Milwaukee Tool 4209 1 Drill 1 1/4 Mag...
How do i program a mag card??
A mag card is simply a card with a magnetic stripe that holds data ... like a credit card or a hotel key, etc. The information on the data is actually just composed of a series of vertical lines. (If you actually had a thin enough magnetic razor blade, you could, crudely, create magnetic data onto a magnetic stripe).
In reality, all you need is a card writer. These are somewhat similar to a cd/dvd burner. You would get a series of blank cards, and you would need the track information and such that would go onto the card. The software that accompanies the write will allow you to input the correct fields, such as name, expiration date, card number, and track 1 & 2 data into the proper fields. Once those are put in, you simply put in a blank card, and "burn" it as you would a cd. The process takes maybe 30 seconds. When I last worked in the industry on that side of things a little over three years ago, a card writer was anywhere from $200 to $450 USD.
Sep 20, 2009 | Computers & Internet
Mag drill will not hold strong to surface
hi first try the magnet on a clean flat piece of m/s sheet/plate 2 inches bigger than the magnetic base ,it should be very hard to remove make shure the magnetic base is clean and the beam you are drilling is paint and rust free if possible clean up the beam with a sanding disc try it make shure the cutter is sharp and use coolant a dull /blunt tool will need more force a good tool almost cuts with no effort on the handle if you are drilling upside down or on the side of the beam NOmagi drill will do this without extra support silk090
Jan 08, 2009 | Milwaukee Tool Milwaukee 4206 - 1...
Milwaukee 4270-21 Compact Magnetic Drill Press Logo
366 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
