This problem should be removed because:
Problem with GE Unitized Spacemaker Washer and Gas Dryer, WSM2480DWW
GE Spacemaker stackable washer/dryer
My washer has quit agitating or spinning. How do I get to the inside and check the belt? Is there a trick? Do I go in through the back or the front? Please help. I don't have the extra money to call a repairman nor do I have the money to buy a new one. Please help me. Tired of going to laundromat.
Solutions (2)
Best Solution
You should go in through the front. Use a flashlight and look between the front panel and the top panel. You should see some clips there. Stick a flathead screwdriver into the clips to pop the top up and then remove the front. The front may be held in by screws, but since I don't know which model you have, look inside once you pop the top and see if there are screws. Then you should be able to remove the front panel and see the belt.
I had to remove two screws on the bottom of the front panel then sort of tip the unit back and it popped right off. pretty easy, actually.
washer will fill but won't "wash"
I have a Ultimate Care II that is 3 years old. One day it filled and started agitating and then stopped in the middle of the washing cycle....
My washer has quit agitating or spinning. How do I get to the inside and check the belt? Is there a trick? Do I go in through the back or...
Washing Machine clutch cleaning
I am wondering how to clean the clutch on my old (1970's) whirlpool washer. It agitates but doesn't spin. I suspect it's due to...
What's the minimum size for
What's the minimum size for front load washer to readily handle a king size comforter?
Add Your Solution
GE spacemaker stackable washer/dryer model
GE spacemaker stackable washer/dryer model WSM2420DWW. I need to remove the front panel so i can replace lid switch. ...
my ge wsm2700dawww fills with water but then
my ge wsm2700dawww fills with water but then nothing
GE Washer/Dryer stacked WSM2480DWW Problem-
GE Washer/Dryer stacked WSM2480DWW Problem- washer unit works correctly and dryer seems to work correctly but no heat. ...
See all GE Unitized Spacemaker Washer and Gas Dryer, Problems
Fix-O-Meter
232
232 people viewed this problem
- 0 people are following this problem. Be the first!
Top GE Washing Machine Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
