Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
20.6 cu. ft. Upright Freezer 24092: My freezer door will not close flush. The bottom ...
My freezer door will not close flush. The bottom is flush but as it gets towards the top thedoor will not close. I can't seem to make the proper adjustment of the door.
  • 523 Answers
Try leveling the unit if that dont work flex the door
Posted on May 06, 2010
Ice forms at the bottom very solidly Model: Maytag MQU1656BEW 15.7 cu. ft. Upright Freezer with auto defrust
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Jul 20, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My upright freezer only goes down to 31 degrees, I have a refill adapter and it shows that R-12 is 52 psi, R-22 is 28 psi, and R-502 is 20 psi. Im not sure what I have in the freezer, i figured you could...
Refrigerators dont loose refrigerant (extremely rare) for the past 20 years .(except Amana ) I think your problem is elsewhere such as : dirty coils , frost on the rear wall (behind panel) indicating a defrost problem , compressor fan or freezer fan not working .
Jul 18, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore upright freezer. left and right outside box sides are fairly warm. Is this common?
yes. This is the way freezers work. Every freezer will do this. If the freezer doesnt do this it generally does not work properly. So to answer your question... its nothing to worry about.
Jul 01, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer defrosting
need to defost the whole freezer get the door to close correctly...
May 27, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Upright freezer--manual defrost
I would check that the door gasket makes good contact with the cabinet. If it does then I would check the temp inside the cabinet. If you have large buildups of ice on the evaporator coils then I would suggest defrosting the freezer and see if that makes a difference. Hope this helps.
Aug 10, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
483 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
