Question about Microsoft Windows Vista Ultimate Edition
Windows Vista Ultimate Edition: with vista on my laptop, how can I connect to my t...
With vista on my laptop how can I connect to my tv
  • Microsoft Master
  • 12,061 Answers
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Posted on May 06, 2010
Thecrow_3@hotmail.comis there a difference between vista ultimate and vista home edition as I did find the code but it didn't work
Yes. Vista Home Edition has less features than Ultimate. Also, it will not run on a different code- nor will Microsoft provide you with one if you have the other
Sep 25, 2010 | Toshiba Satellite A135-S2386 Notebook...
25 codigo
DONT FORGET TO RATE ---------------->
windows vista ultimate
S/N: YFKBB-PQJJV-G996G-VWGXY-2V3X8
Microsoft - Windows Vista Ultimate
VMCB9-FDRV6-6CDQM-RV23K-RP8F7
GLAD2-SEEUH-AVEAS-ENSEO-FHUMR
29103-30-33224
11111-11111-11111-1111-1111-1111-1111
Microsoft Windows Vista Ultimate Final
PVYFQ-2JTBV-PKXQ2-FQHDY-MTBVH
Microsoft Windows Vista Ultimate Final (activation)
FBK3P-9HCG-YJGBB-CRVGV-X32M9
Jun 16, 2010 | Microsoft Windows Vista Ultimate Edition
I have opened the laptop and then find a red dots on the screen, I can see the the red dots in the black area are more. I tried to solve the problem using the JScreenFix put there is no ues from it..hope...
i think you dont have an original key
change your key with one of this
29103-30-33224
DONT FORGET TO RATE
Jun 16, 2010 | Microsoft Windows Vista Home Premium...
Windows Vista Ultimate 64-bit
SEARCH THE 64 BIT DRIVERS IN GOOGLE SEARCH.
Sep 09, 2009 | Toshiba Satellite A205-S4617 Notebook
I Have Upgraded To Vista Ultimate And I Still can,t add annimated gifs to my laptop can anyone tell me how to solve this problem as i was told that you could only do this on vista ultimate . i upgraded...
For an animated desktop wallpaper in vista ( available only in ultimate version), you will need to run the windows vista ultimate extra updates namely - "WINDOWS DREAMSCENE". After that update you can set any vedio as your desktop baground.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
Are they the same - windows vista 32 bit platform edition and windows vista home basic 32 bit sp1
Yes and no. Think of 'platform' as a general header when looking at operating architectures (there are different types) and Vista choices.
Vista choices under the 'platform' 32-bit are:
• Windows Vista Home Basic 32-bit
• Windows Vista Home Premium 32-bit
• Windows Vista Ultimate 32-bit
• Windows Vista Business 32-bit
• Windows Vista Enterprise 32-bit
Another example of the "64-bit platform" and Vista choices are:
• Windows Vista Home Basic 64-bit Edition
• Windows Vista Home Premium 64-bit Edition
• Windows Vista Ultimate 64-bit Edition
• Windows Vista Business 64-bit Edition
• Windows Vista Enterprise 64-bit Edition
Mar 05, 2009 | Dell Computers & Internet
25 Character product key
You have vista Home Edition? If it came with your laptop, then check under the laptop for the 25-character key. The key is tied into the version of Vista you can use on that laptop. So, if you try to install Ultimate on a key that is for Home Premium, then it will not work.
Feb 18, 2009 | Microsoft Windows Vista Ultimate Edition
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
Hallow Dear,
Please use this link to download Drivers for your PC (20M)
XP/Vista - ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Operating Systems
Microsoft Windows 2000
Microsoft Windows XP Home Edition
Microsoft Windows XP Media Center Edition
Microsoft Windows XP Professional
Microsoft Windows XP Tablet PC Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Ultimate 64 Edition
This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
(I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Upgrade to vista ultimate
If you have a full version of Windows Vista Ultimate, you can just insert the DVD when you logged in your laptop and go to Computer(My Computer) and lauch the installer for Windows on DVD icon (Double Click DVD icon). It will give you the main window for installing Windows and along the way, you should find an Upgrade option. Click that one and it will install windows Ultimate on your system. It Will not format the laptop but installer will just add system files and features to the laptop to run Vista Ultimate.
**If you haven't purhcase a Windows Vista Ultimate Disc, check this link to to purchase just an upgrade Disc (only) of Vista Ultimate.
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
An upgrade disc will also not format the laptop instead it will just install additional features and add additional files on the system to run Windows Vista Ultimate
Oct 28, 2008 | Sony VAIO Digital Studio VGN-AR320E...
Upgrade vista home premium to bussiness edition
Upgrading from home to business edition in vista, we have to loss fewer things. Because home edition does not support for the domain functions. But its very fast and easy
here, you have a link. it may be useful for you..
http://www.microsoft.com/uk/windows/products/windowsvista/buyorupgrade/windowsanytimeupgrade/faq.mspx
Jul 22, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
