Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Hello I have a Xerox Phaser 3300MFP and there are 2 erros that are flashing on the panel. 1. Intenal Error wer off/on 2. Bb-datamgr.c 487-T. All the buttons on the panel dont respond.
  • Anonymous Mar 17, 2014
    Phaser 3300mfp error 40a36af8 3T 915 Rip. Cannot print, scan or copy.
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
  • spml28
    spml28 Nov 27, 2012
    Donde esta la bateria que usted dice
  • Espartaco Toorrents Oct 23, 2013
    tienes que retirar el panel completo donde esta el teclado.
  • Xerox Master
  • 12,061 Answers
Http://www.refillbros.com/en/manuals/p1656-xerox-phaser-3300mfp-service-manual?page=268
The above link, is an online service manual, this will tell you everything to do with your errors and how to fix them
Posted on May 06, 2010
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Printer indicates Sacanner locked
  1. Unlock the Scanner by reaching under the Control Panel on the left side and pulling the green lever forward.
  2. Press the [Stop / Clear] button on the Control Panel.
Jun 04, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Scanner locked on Xerox phaser 3300MFP
There is a green switch on the top of area where paper comes out. That locks the scanner
May 12, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My workcenter PE220 Xerox is displaying scanner locked and it is not printing or copying. What do I do?
The manual says to unlock it. You will probably need the same password that you used to lock it.
Mar 23, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Internal Error wer off/on BB_DataMgr.c 487 T in xerox phaser 3300 mfp
Solo hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Mar 09, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
How do I unlock the scanner on the xerox 3300 mfp?
DEBAJO DEL PANEL DE MENU (DONDE SALE EL PAPEL), HAY UNA PALANCA CORREDISA QUE BLOQUEA Y DESBLOQUEA LA LAMPARA DEL ESCANNER, ESA ES LA SOLUCION.....
Feb 15, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Need to find out how to get a meter read for my phaser 3300 xerox
Press "Menu". Scroll to "System Setup". Scroll to "Maintenance". Scroll to "Supplies LIfe". Scroll until you find the total count.
Jan 20, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My Xerox phaser 3300 mfp scanner is locked. How do I unlock it?? Thanks so much.
Look under the scanner area-Where the finished paper copies come out- There is a little green Tab. Pull Green Tab forward.
Dec 15, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Paper jams every time
try to turn off the printer, unplug cables and remove the toner, then check if there loose papers inside the machine. You can use flashlight to determine if there are such loose papers. Then reinsert the toner, insert the cables and battery and turn on the machine. If symptom persist, consult xerox phaser for possible repair..
Aug 24, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
3,091 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
