Question about Philips Magnavox 42MF521D/37 Television
Flatsreen tv as a computer monitor
Good afternoon, i was wanting to use my flat screen tv a a computer monitor. i bought the hardward connection all is well w/that, however the
TV states there is not data even though i am on the PC channel. do i need software or something to get the computer and tv to communicate?
    Problem Solver:
  • 5 Answers
Here are some questions. Are you using two monitors or only the flat screen? Also, what type of cable are you using, RGB, DVI, HDMI, S-Video? It should say on the back of the TV where it is plugged in if you're not sure. Another thing is if you are using the video coming from the motherboard of the PC or do you have an independent video card. The TV should act just like a normal monitor depending on your connections. If you have any questions let me know and I'll help as much as I can. Good luck!
Posted on Apr 21, 2008
Good afternoon. I have an LCD . When I turn it
Sometimes LCD screens can flicker if kept in cold environments. Make sure that it's not too cold in the area of the LCD. Also, make sure the cable to the monitor is connected properly, as a loose cable can also cause the screen to flicker.
Mar 05, 2011 | Samsung Computers & Internet
I bought the Panasonic 3D Viera TC-P42GT25 wi fi ready tv, and it said in the manual that I can connect my PC to the TV and use the TV as a monitor for my laptop. I bought a wireless keyboard/mouse, and a...
looking at you laptop keyboard, you should be able to find a key that has a small picture of a monitor on it... normally will be one of the F or numeric keys... find this key first, then activate the external display function using that key (maybe by pushing the F key and the Key we found) typically for each time you click to activate that function, your computer will switch between three modes: internal + external, internal only or external only... good luck
Jan 25, 2011 | Televison & Video
Have damaged screen extensa 4220, can i connect laptop to tv ? which cable do i need?
well u can connect it to a computer monitor or to TV by using this product
follow this link to see it and all the required cables are included in the product
http://sewelldirect.com/pc-to-tv.asp
but my advice is if u want to connect ur laptop to an old TV (Not flat and doesn't have a high resolution) don't connect to it and buy a new LCD screen to ur laptop , so just connect ur laptop to any TV which is flat or LCD and have a high reolution cause u may face a problem in colors and resolution
good luck
Aug 14, 2009 | Acer Extensa 4220-2148 Notebook
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Westinghouse 26" tv SK-26H730S HDMI screen blinks with Dell Comp.
try using the 27 pin monitor input instead the hdmi possibly has a frequency variance
Mar 01, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Want product info
No Monitor had DVD Player Connector But there is a solution to connect dvdplayer to monitor that is TV Tuner Card it costs around 20$ in the market.
Thank U
Apr 05, 2008 | Gateway FPD2275W LCD Monitor
LCD TV
was the "nix" on the screen of the console
Dec 14, 2007 | RCA Alert Guard 20" Flat Screen 20F670T...
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Philips Magnavox 42MF521D/37 Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
