FixYa.com
Tags:
Fuji FinePix Z1 Digital Camera
I have a FinePix Z1 (by 2 users)
posted by jkwas3 on Mar 26, 2008
I have a FinePix Z1 I have installed a new battery and it is fully charged. The problem is that the camera shuts down within 20 seconds. I slide the front and it restarts only to shut down again. I have reset the camera via the menu and every time I try to go to the menu the camera shuts down. I have just taken 22 pictures went to the menu to turn off the lcd saver and the camera shut ndown Please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by swiss6314, posted on Mar 27, 2008
card not initialised is showing up on the screen and I dont know how to fix it - please help!!
Best Solution
posted on Apr 25, 2008
Thanks for Trying (70)
raelcohen
Rank:Apprentice Apprentice
Rating: 75%, 3 votes
try a different battery - how old is the camera - the voltage may be too low, hence it turns off.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 18, 2008
Not Rated (0)
mad al
Rating: 0%, 0 votes
I also have a Z1 which shuts off frequently. It also sometimes fails to switch on at all. If the top of the front slide panel is depressed when opening, camera more likely to power up, but tricky to use whilst holding top tightly.
At least by this means the camera can be made to operate!
Can you Help with these Digital Cameras problems?
horizontal lines in the...
Help, I have a Fuji FinePix Z1... Answer This...
shoots negative size photos
every time i up load the photos... Answer This...
Problems with display
There is a problem in finepix... Answer This...
Fuji FinePix z1
My Auto flash will not work... Answer This...
finepix z1 does not turn on!
I have a finepix z1, when I try... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
