Here is a list of things to try:
Note: Start with #s: 6, 7, and 9
1. Uninstall and reinstall the sound drivers
2. Install K-lite codec pack
http://fileforum.betanews.com/detail...d/1094057842/23. Start > Programs > K-Lite Codec Pack > Configuration > Codec Tweak Tool and check the box next to [Registry] Fix non-working system sound
4. Make sure the volumes are not set to zero and that nothing is on mute Control Panel > Sounds and Audio Devices > under Device Volume, click on Advanced
5. Make sure that everything in Device Manager is fine (no yellow or red marks) Control Panel > System > Hardware tab > Device Manager
6. fixnoflashsound.reg (just click on the link and install it)
http://files.filefront.com/fixnoflas.../fileinfo.html7. netvol.reg (use Internet Explorer to click on the link and install it)
http://www.kellys-korner-xp.com/regs_edits/netvol.reg8. If possible, make sure Digital Output Only is not check marked (not all cards support Digital Output Only)
http://tomebling.home.comcast.net/~t...oundConfig.jpg9. Confirmed the presence of msacm32.drv and msacm32.dll
Search for these files in C:\Windows\System32
If you don’t have it, download it from here:
http://www.filesavr.com/msacm32Made sure speakers are properly connected to sound card
Run SFC /Scannow
Start Menu > Run > type this in exactly (note the space between C and /): SFC /Scannow
Tried different Video player
Installed Quicktime Alternative
Reinstalled DirectX
Confirmed presence of "plug and play software device Enumerator"
Made sure that default devices were selected
Control Panel > Sounds and Audio Devices > Audio tab
Tried using different settings in the sound card’s configuration window
Installed Microsoft ADPCM Audio Codec and IMA ADPCM Audio Codec
for %x in (C:\WINDOWS\System32\*.dll) do regsvr32 /s %x
Thanks
