Question about Garden
Honda lawn mower. Engine 'hunts' then stops.
This is a recent situation on my Honda lawn mower which is fitted with a 5.5 hp GXV160 engine.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
Cleaning the air cleaner element helps this problem also
Gav
Posted on May 07, 2010
Testimonial: "Filter now ok also spark plug so now ready to clean carburette"
  • 3,740 Answers
In either case. Here is how to clen the carb properly:
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
NOTE if fuel does NOT stop when float is level you will need to bend the float tab (tab up if level is too high or tab down if level is too low) where the needle attaches to the float assy until it does.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
Step 8 is VERY important"
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
If it is still hunting gently grasp the carb and try to move it up or down. Your checking for loose mounting bolts. If it is loose tighten the 2 mounting bolts.
That should do it.
If the engine STILL hunts after all of the above there is still more I can pass on to correct the situation. We just need to communicate by you letting me know that you still have the engine hunting problem.
Thanks for using FixYa.
Kelly
Posted on May 06, 2010
Testimonial: "than you for your help, an expert on hand"
Lawn motor backfire when starts?
Change the laminator. Part the spark plug wire is connected to. Air gap should be .025.
Jun 05, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Wont start
Flush gas tank, fill with fresh gas and Stabil. Replace air filter. Remove bowl from carb clean bowl and holes in bowl screw.
Mar 07, 2014 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
HONDA MOWER CARB. LEAKING GAS OUT OF CARB
Replace carb gaskets. Replace carb bowl gasket.
Jan 15, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Honda mower won't pull start
you will need to find out if you are getting a spark. generally cheap to fix it you just need to find out which part isnt working first
Jun 03, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Replacing crank shaft
Unless you have experience on how to tear down an engine, you're bette off leaving this to a machine shop or small gas engine shop.
May 24, 2012 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Honda lawn mower stops running
Flush gas tank, reill fresh gas & Stabil. Replace air filter and plug.
May 13, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
I need a repair guied to tare apart this engine
Model Number Search : eReplacementParts.com
Go to this site, it is one of the best I have found for Honda parts.
Put in your model number and you can find all parts in good exploded views.
Gary
Feb 15, 2011 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Garden Logo
632 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
