Question about Degen DE15 FM Radio
Degen 1125 and no instruction book
Breif instructions on how to opperate. Set radio chanel. Record set time radio. etc
Need instructions for stopping buzzer. Would like alarm to be radio.I have lost my instruction book. Model T311T.
press the top button on the right until the radio comes on, then set the alarm time.
Mar 15, 2010 | Timex (T307S) Clock Radio
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
I have a Timex N3 Radio Controlled Wrist Watch, but cannot find the instructions on how to set the functions. I have looked at Timex.com, but cannot find the model there either. The watch is approximately...
It seems likely that the setting instructions for radio controlled watches of one make are very similar so almost any of their radio controlled watch instructions may be used.
The user instructions list includes ones labeled "universal radio controlled book". Choose the one for your area and follow the instructions. You have nothing to loose!
Good luck.
Jan 15, 2010 | Watches
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
HSD128A projection clock came with chinese instructions
Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
Mar 30, 2009 | GPX D725 Clock Radio
DEGEN DE1103
I have the same problem .The controler has to be replaced .
Where to get one is my problem .
Jul 05, 2008 | Kaito KA1103 SW/FM/AM Radio
Answer machine
I HAVE A VTECH PHONE AND LOST POWER TO IT. AND I'M TRYING TO SET THE ANSWERING MACHINE UP, I CAN'T FIND THE INSTRUCTION BOOKLET AND I CAN'T FIND IT ON THE INTERNET. I HAVE A 5.8GHZ VTECH MODEL IA5874 VTC-IA5874-R. I KEEP GETTING THE LETTER (A) ON THE BASE PHONE AND IT WILL NOT RECORD ANY MESSAGES THAT ARE LEFT. I DID WHAT THE MENU SAID TO DO BUT STILL WONT RECORD ANY MESSAGES, NEED HELP TO WHERE I CAN FIND THE INSTRUCTION BOOK OR HOW TO FIX IT. THANK YOU
Oct 15, 2007 | Vtech 5.8GHz Cordless Phone with Digital...
Degen DE15 FM Radio Logo
653 people viewed this question
Top Degen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Degen Audio Player and Recorder Expert? Answer questions, earn points and help others
