Question about Sony Cameras
Sony cybershot DSC H9 Error C:13:01 Reinsert memory card
Recently, during my friends 25th Wedding Anniversary I took photos and video clips I used 8GB Sony Memory Stick Pro Duo, Made in Japan..while taking video the Memory Stick was full and the battery was low and the error C:13:01 started flashing on the display reading "Reinsert Memory Card,". For me the pics and videos worth million dollars..Kindly provide me with a solution. Neither My camera reads the Memory card nor my PC and Laptop. Kindly I need your help to resolve this issue. Thank you very much in advance. Best Regards, Syed Mahmood Hussaini, Dammam.
sonyspares
  • 89 Answers
SOURCE: Memory Stick Pro Duo 1GB
First try and clean the card slot. If this does not solve the problem, replace the memory card and try.
Posted on Dec 30, 2006
scrodamoon
  • 659 Answers
SOURCE: sony memory stick pro duo
Well alot of the time there is a issue with the formating that the camera does on the stick and also when formating it on the computer it formats it another way as well. some in FAT and some in FAT32 this is ushally a error for the most part I would definatly plug your duo stick into a card reader and then go to my computer and the find the drive that the stick is in and right click on it and go to properties and do a error check on the stick to make sure that there is no errors. and if you can defragment after the scan then by all means do it and then format the card and try it and hopefully it will work out to your advantage.
*note this problem seems to only happen with the non branded duo sticks not the sony branded ones.*
Posted on Aug 02, 2008
Kasm279
  • 95 Answers
SOURCE: CAN'T USE 2GB SONY MEMORY STICK PRO DUO CARD IN MY DSC P92,
Well, it seems as though this camera can only take 128MB sticks, but they are cheap if you can find them. Also, capitalizing everything does no good as it makes a post hard to read, shouts, and will get ignored by a lot of people.
Posted on Apr 02, 2010
SOURCE: Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Posted on Jun 17, 2010
  • 11967 Answers
SOURCE: I have an 8GB memory
That's because you used your Mac to erase the pics from the card instead of the camera. Now, to get it to work properly, you need to format the card in the camera.
Posted on Aug 08, 2010
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
I have an 8GB memory stick duo. took pics and downloaded them ok. deleted from my mac-when i reinsert the stick into camera (Sony DSC T9 6 megapixel cybershot) it says formatting error. help
Aug 08, 2010 | Cameras
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony cybershot dsc-w130 keeps showing "reinsert the memory stick" when i try to take a pcture or adjust telephoto when i do it does not make any difference
Oct 06, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Sony will not read 8gb Sandisk memory card. States, Reinsert memory card and flashes c:13:01
Check your owners manual...can your camera handle an 8gb card? Maybe all you need to do is format it in the camera.
Oct 06, 2009 | Sony Cybershot DSC-T200 Digital Camera
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Sony Cybershot DSC-H9
Trey to format internal memory, replace memory card, it may be faulty
Sep 22, 2007 | Sony Cybershot S650 Digital Camera
Cameras Logo
410 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
