Question about Sharp AL 1631 Copier
Sharp AL1644 machine does not operate as a photocopier
Sharp AL1644 The photocopying side of the machine is not responding whilst it is operating ok as a printer scanner from the computer. The start button light is on. Display shows 0 (zero ). Have switched machine off and on. Have also disconnected and reconnected cable from computer.
  • 1,110 Answers
Do you have any status lights on? If not then you may just have a print button that needs repaired. I have seen this a few times on this series. Try pressing down firmly on the print button while wigging the button around in a circular fashion. If you work a it and all of a sudden the machine makes a copy then the solder connectioons for the print switch have worked loose and will need to be re-soldered. Pretty simple repair. You may have someone locally that can do it. The operation panel comes off pretty easy and the circuit board with the switch is right under this panel. It is a small "button" type switch with small solder contacts that break loose. 10 minute job if you know what you are doing. 20 minutes if you dont. Just need someone with a solder iron and a little skill.
Good Luck and Thank You for using Fixya.
Posted on May 06, 2010
I need a software that can enable me print from my 26 bit computer and my copier AR-M207 PHOTOCOPIER
You can download a printer driver from here.
http://www.sharp-world.com/support/download.html
Microsoft is ending support for Windows XP so I would suggest updating your operating softwaere.
Mar 09, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
WHERE CAN I FIND A DRIVER for SHARP AR-153E copier WITH WINDOWS 7 OPERATING SYSTEM please. thanks
Go to the following site. Select your Product (Photocopier AR-153E) and Operating System (Win7) and download Drivers
http://support.sharp.net.au/drivers/driversearch.asp
Hope this helps.
CreativeTECH
Nov 12, 2010 | Sharp AR-153E Copier
AL1644 Sharp
For a Sharp AL1644, pls start here. Clicking on the Click here under "Drivers and Software Downloads" would open another window, pls enterxx in the box provided for the "Select a Product Code :" and click on "Search" button. Select driver appropriate for your Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Sharp AL 1631 Copier
Sharp photocopier arm205 toner dust on about the first 10 pages when machine is cold.-Then it clears up.
soething wrong with
1-drum blade
2-"waste toner" cleaning mechanism
I would replace the drum blade, empty the waste toner and check to make sure it is operating ok.
Aug 25, 2008 | Sharp Office Equipment & Supplies
Sharp AL 1631 Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
