Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
Posted on May 06, 2010
I went driver sony dcr-hc28 - Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Anonymous
Level 1:
New Friend:
  • Contributor 74 Answers
  • Posted on May 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
74
Questions
0
Helped
20766
Points
98
Go to http://www.sony.com
38helpful
5answers
2helpful
2helpful
On a Sony Handycam DCR-HC28 there are grey lines running horizotally during play back mode. Both on the camera touch screen and on our TV when we play it back.
Cleaned my heads and internals with alcohol and q-tip and blew it out with compressed air( LIGHT PRESSURE) approx 30 lbs press. works great.
I get a c31:23 error message on sony camcorder dcr-hc28. Any suggestions to fix this?
That code is telling you your heads dirty, no do not buy Shampoo just a tape head cleaner from local camera centre, all will be fine okay?
David
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Connecting Lyd Model#203 mini-cam to Sony DCR-HC28 Handycam
The HC28 has a/v out only - whereas the HC32 has a/v in/out capability of which only certain models of camcorders have.
3helpful
2answers
Driver download
pls provide Sony Handycam DCR-HC28 driver file for win xp sp3
4helpful
5answers
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
