Question about Apple MacBook Pro Notebook
MacBook Pro/ ParkerVision SIGNALMAX WR1500/ Compatability?
We have 4 Windows XP Computers operating happily on a ParkerVision LAN. We added a MacBook Pro and it operates on our LAN it receives its data on the wireless network so very very slowly that it is practically useless. Do we have a compatability issue with our ParkerVision SIGNALMAX WR1500? Our oldest and slowest computer downloads from the Local Area wireless Network more than ten times as fast as the MacBook Pro. How do we get a ParkerVision driver for the MacBook Pro?
  • LDavisMichel Mar 29, 2008
    We went with ParkerVision because we have a distance problem for one of our computers. They have served us well untill we added the MacBook Pro. The 11 Mps top speed on the Mac is an imposed restriction. Our other computers download from the satalite at bit rates frequently in excess of 110 Mps.
    If we replaced our ParkerVision and its Way Points and cards we would be looking at non trivial costs.
    Is there any brand that you can recomend as having both long range and high speed?
    Thanks for the input!
    Yours, Davis
  • LDavisMichel Apr 01, 2008
    Perhaps I should add a second wireless router 802.11 n for the apple which does not have the range problem. The MacBook Pro just has no speed on the ParkerVision System. If Apple supports Airport Extreme/ 802.11n then this might clear the bandwidth roadblock without disturbing an otherwise working system.
When working with wireless networking, increased range is usually a matter of either a higher gain antenna, another access point or both. Also, you can use 802.11n for increased range. Apple uses this standard but calls it Airport Extreme.
http://www.apple.com/wifi/80211/
Posted on Mar 30, 2008
    Problem Solver:
  • 6 Answers
It looks like the product is no longer supported by ParkerVision and no Mac driver was ever produced. The device you mention uses proprietary technology to get the performance you are seeing.
http://www.wi-fiplanet.com/reviews/article.php/3445641
I would bet that it would be easier to replace your router with a new one that uses industry standards that all platforms support.
Posted on Mar 28, 2008
  • Tim Lewallen
    Tim Lewallen Mar 30, 2008
    Usually increased range is achieved via the use of higher gain antennas, additional access points or a combination of the two.
    You can also use a router that uses the 802.11n standard for increased range. Apple uses this standard but calls it Airport Extreme.http://www.apple.com/wifi/80211/
    When possible, I recommend using industry standard technologies to avoid issues like this.
    Hope that helps.
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
I am a windows running computer connected to a Parkervision signalmax wr1500 router... I have internet access but my laptop (mac) cannot find the network that was previously accessible. What did I do...
If your mac is trying to connect wirelessly? If so, did you secure your wireless by disabling the broadcasting of the SSID?
If you have disabled SSID broadcasting (which is a good security measure), you will probably need to manually add the wireless network and key to get this to work.
Hope this helped! :)
Oct 16, 2010 | ParkerVision SIGNALMAX WR1500...
Need the transformer specs for ParkerVision WR1500-WR3000
p/n 30-112-120602
model ad48-1201200du
here you go
input 120vac 60hz 250mA
output 12vdc 1200mA
Apr 26, 2010 | ParkerVision SIGNALMAX WR1500...
How do I secure my parkervision wr1500 router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Mar 24, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
What is the parkervision wr1500 defaul password?
By default your password for this router is 1234, but if it doesn't work it means that it was change already so better try your commonly use password and if still wont work reset the router to bring it back to its default settings with default password.
Mar 23, 2010 | ParkerVision SIGNALMAX WR1500...
Specifications for AC Power Adapter
In is 110-120 vac and 12.0 vdc.
Hope this helps!
Visit us at http://www.nipycom.com for more help.
Dec 19, 2008 | ParkerVision SIGNALMAX WR1500...
Voltage/Ma of AC adapter for WR1500??
The power supply on my ParkerVision WR1500 router is 12 vdc, 1.2a, center pin positive. http://straylightsoftware.com/downloads/parker2.html
Oct 29, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
Apple MacBook Pro Notebook Logo
134 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
