Question about SanDisk Sansa m230 MP3 Player
Sansa m230 delete specific song from the player
What is the step to delete the one song from the player without connecting to PC? OR how to delete the song after connecting to PC?
Can you please explain the steps to do this? Thanks a Million.
Thanks.
  • himru Mar 28, 2008
    GRRRRRRRRRRRRREEEEEEEEEEEEAAAAAAAAAATTTTTT. WORKED very well. Thank you very much.
  • 758 Answers
Your SanDisk Sansa does not allow you to delete files from within the player.
Instead I recommend that you follow the steps below to delete the music
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computerSansa m230  delete specific song from the player - 1.gif..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music1.gif and delete them from there.
Either under sync panel in your windows media1.gif player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Mar 28, 2008
How do i delete songs off my sansa m230 so i can add new music
Connect the Sansa to your computer using the supplied cable. Open up the operating system's explorer window. The Sansa will show as either a Sansa or a removable hard drive, depending on the USB mode. Either way, open it and you'll see a folder named "MUSIC". Open that. You can either delete entire albums or navigate into them and delete individual tracks.
Mar 10, 2010 | SanDisk Sansa m230 MP3 Player
How to delete songsfrom m230 sandisk
The easiest way to delete songs from it will be to connect it to your computer-> Open the mp3 folder and select the songs you want to delete. Hit shift+del to delete them. Then close the window, use the safely remove hardware to stop the device and disconnect it from your computer.
Dec 02, 2009 | SanDisk Sansa m230 MP3 Player
How do i delete songs?
1. connect it to your computer (through usb)
2. go to "my computer"
3. go to sansa (which should have appeared in "my computer")
4. select the songs you want to delete and click DEL (or drag them into the trash can)
hope that helps!
Jun 10, 2009 | SanDisk Sansa m230 MP3 Player
Cant delete music
Connect your sansa to the computer and then explore the drive and delete . also empty the recycle bin not to occupy space from your computer storage.
melnavz
Jan 23, 2009 | SanDisk Sansa m230 MP3 Player
I can't delete music from my sansa m230!!!
Plug in the player. Then go to my computer and find the player. Then right click it and hit format. it should erase the songs.
Nov 18, 2008 | SanDisk Sansa m230 MP3 Player
Won't delete songs
You should be able to modify and delete playlists/songs by connecting the player to your computer and accessing the files by going into my computer and selecting the player drive.
May 20, 2008 | SanDisk Sansa m230 MP3 Player
Help with getting old music off sansa m230
Try going to "My Computer" clicking on Sansa, opening the music folder, and deleting the songs from there.
Mar 10, 2008 | SanDisk Sansa m230 MP3 Player
Erase everything from my Sandisk M230
Hello!
Im affraid to answer this question. because i only gain' thanks for trying" but its ok.
In your case , If you want to delete all files in your sansa, maybe you can delete it by formatting your sansa disk. You can find maybe the format on the menu and select format the disk(something like that.) Or you can connect the sansa to the computer and delete all files in there. You can browse your files in the my computer and select the drive created by computer when the sansa is connected.
may this help, melnavz
Mar 06, 2008 | SanDisk Sansa e200 MP3 Player
Deleting songs???
You can delete the songs thru the PC.
My Computer>Device Name (m230)>Music Folder.
Just right click and select DELETE on the songs you dont want.
Best of Luck.
Please RATE my solution BELOW.
Nov 27, 2007 | SanDisk Sansa m230 MP3 Player
Sandisk m230
Hi big dee. Deleting songs from your M230 can be done by either browsing the player through your Windows Explorer and then selectively deleting the music file, or by formatting the player which would delete all of your music files. It's also important to know that your player has 2 modes -- MTP and MSC -- because music files saved in one mode would not be seen in the other mode, and vice versa. To switch the modes on your player, use the menu and navigate as follows: Menu > Settings > USB You would get a choice of "Autodetect" (this is for MTP) and MSC. Here's how to delete the files: Step 1: Plug in your player to your computer. Open explorer and check if your player is detected. Your player's LCD would display "USB Connected" and the mode would be indicated below that. If your player's mode is MTP: A. Look for the Sansa M230 icon on Explorer (it will be recognized as a Portable Audio Device). Double left click on it to browse the player. B. The player will have 2 sub-folders: "Data" and "Media". Double left-click on the "Media" folder and either find your music files or open the "Music" folder to find your music files If your player's mode is MSC: A. Look for the Sansa M230 icon and drive letter on Explorer (it will be recognized as a "Removable Drive". Double left click on it to browse the player. B. The player will have several sub-folders such as "Audible", "Config", "Record". You may already be able to see your music files or the player may have a "Music" sub-folder. Open that to check for your files Step 2 Once you've located your files, you may now be able to delete them. Step 3 Once you've unplugged your player, the M230's LCD will display the message "Rebuilding Library". Let that process complete, then you may turn on your player to confirm that the files have been deleted. To format your player, just right-click on the M230 icon in Explorer, then select "Format". When the Format window appears, make sure to select "FAT" as the File System type, and also make sure that the "Quick Format" checkbox at the bottom of the Window remains un-checked. I hope this info helps. Enjoy your M230. :)
Apr 25, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
133 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
