Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Stihl ms 192 T chainsaw. cranks ok, will idle fine and i can slowly pump the throtle to get it to accelerate, but when i try to accelerate full throtle it dies out. have already put a carb kit on it. plus just replaced fuel pickup filter. what is the round piece that is by the carberator that has 1 fuel line ran to it, it looks like either a vent or what i was thinking like a type of pvc valve or check valve? thank you for any support
  • dontbother10
    dontbother10 May 11, 2010
    Hello Willard; 1 - My knowledge base for Stihl is very limited. That said I know they plug up mufflers and spark arrestors faster than any other make. Have you tried cleaning it? If this solves the problem please post back and I will close your question. 2 - I suspect you are correct and it is a fuel vent. If Stihl allowed IPLs it would be simple to answer; sigh. 3 - Lou, Good Luck
3 Suggested Answers
SOURCE: Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Posted on Sep 19, 2010
  • 26 Answers
SOURCE: cuts out on acceleration
if you have over 200 hours on this FS 80 then you may need a valve adjustment(yes this 2-stroke has valves). if you wanna try to do it yourself it should be set @ 0.1mm @TopDeadCenter. my advice is take it to any stihl dealer and let them do it. its scheduled maintenance
Posted on Feb 27, 2010
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Stihl f5 55r dies when giving gas - gas vent problem?
Sounds like a carburetor adjustment issue. Try turning the screw closer to the engine, on the carburetor, SLOWLY in small increments in a counter-clockwise direction, and squeeze the throttle between moments letting it settle back to idle until it will accelerate and run. Then, fine tune it; the more you go in, the less fuel mix and the leaner the idle, the more you come out, the richer it gets and the response should pick up.
Apr 06, 2012 | Stihl Garden
Stihl fs55rc crab problem willnot run full power
You probably need to adjust your carburetor. You can slowly turn the jet closest to the air filter in 1/8 turn increments while at full throttle and check the response. Ear protection is necessary to be able to distinguish the RPMs from the audio pitch of the running engine.
Mar 28, 2012 | Stihl Garden
How to start stihl ms 180 c
pull choke full on pump petrol 5 to10 times it should try to start take throtle of full to next button and try again
Jul 17, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Stihl line trimmer FS46 Runs good at full throtle
the smallest piece of trash will cause you the biggest problems. try blowing the carb out . i think it has a pre set idle on it.
Sep 18, 2009 | Garden
New Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Mar 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a stihl 021 chainsaw that will crank and idle fine however it will not throttle up to full speed ,it will accelerate to about half, then it just like chokes out.
For the 021...on the muffler, there is a spark arresting screen, this is to prevent sparks from coming out of the muffler. It is common for this screen to become clogged with carbon from the engine. You will need to clean/replace this screen in order for it to run correctly.
Feb 28, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
475 people viewed this question
Top Oregon Scientific Garden Experts
Dan Connors
Dan Connors
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
