Question about Dishwashers
I have a 2 week old Beko dishwasher and last night I noticed that the lights were all flashing, I switched off and opened the door and the bottom of the machine is full of water. Any ideas?
  • 784 Answers
Either there is a leak activating the error alert or there is some blockage from the drain hose to the food dispenser.
Unplug the power cord for 24 hour to reset the disrupted logic back to the original stage to see it it help. If the manual shows the diagnostic mode, try to set to manually drain so a new cycle can be started to test.
Posted on May 08, 2010
Beko de2542f dishwasher
If you live in Rancho Cordova, CA and need dishwasher repair service call us at 916 823 3070 or visit our website Dishwasher Repair Rancho Cordova 916 823 3070 GE Maytag Ken
Sep 03, 2017 | Beko Dishwashers
I noticed just as going to bed last night that our dishwasher appeared to be making a strange noise (dull buzzing sound), opened door to check and the display has the number 3 flashing, several fault codes...
check the very bottom of washer; look for something jamming the garbage cutting blades. it can be something very small stock half way in the drain causing the blades to stop turning and therefore keeps it from draining water. just an idea
Dec 16, 2014 | Hotpoint-Ariston LFT 228A 23 in Builtin...
665 dishwasher
If the door is not locking properly there is a chance that the door lock switch is not being closed. This will shut off power to many of the circuits, including power to the water fill solenoid, etc. Latch mechanisms are available separately.
Sep 19, 2017 | Galaxy Dishwashers
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
heatman101
Sep 18, 2010 | Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Dishwashers Logo
254 people viewed this question
Top Dishwashers Experts
