Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirpool quiet partner 2 normal button flashing, reset not work
I have whirlpool quiet partner 2 dish washing machine with no. SPD 8575584 purchased in Mexico from Cosco shop. By my suprise after guaranty time just 2 weeks after it commenced to have problems.
Service man give me solution with change of panel inside with cost of 90% of purchaser odf whole machine!? So I deny it. Machine was working with problems for 6 months. (usually blinking clean button)
But now blinking constantly NORMAL button, machine wont start only after reconnecting from power drain function is working.
I have to admit that machine is connected to hot water directly, I have solar panel so water is relay hot.
I tried to use combination of pressing the sani and dry buttons, heated dry + hi temp. without results.
Any idea what else I can do? With regards & best wishes from Veracruz
Robert Pozniak
4 Suggested Answers
  • 530 Answers
SOURCE: Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Posted on Mar 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool quiet
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Posted on Nov 15, 2010
kdrake84
  • 262 Answers
SOURCE: Quiet Partner II Whirlpool Dishwasher 2 years old,
Unusual LED or
Display Readouts
Open ID diodes and/or LED
circuit(s) in keypad, or open
circuits on the control that drive
See "Checking Keypad Operation."
Press the following in sequence...Then try touch pad......
HEATED DRY ? NORMAL ? HEATED DRY ? NORMAL ? HEATED DRY ? ORMAL
here is the deal...if the touch pad is unresponsive after entering the above in sequence then you will need to change out the touch pad.
here is the link to your model....part number 1 on the drawing...there are three different ones....the difference is the color.Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPBA/1198/0130000/W0702219/00002?blt=06&prst=&shdMod=
Here is a link that will show you the three differnet colors...I would order from these guys....1 year warranty on parts no questions asked
click on the link http://www.repairclinic.com/Touchpad-Parts?s=t-DU1100XTP-%3d%3dc63
Posted on Feb 28, 2011
Whirlpool quiet partner III
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
high temp wash
heated dry
high temp wash
heated dry
all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
I Hope this works for you.
Dec 18, 2013 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How do i check for gloggged jets
clean filters,then run a wash tablet through machine without a load.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
177 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
