Question about Xerox Phaser 8400 Laser Printer
Xerox on a 8400 faults code 37004 403B25998 what does it mean
  • Xerox Contributor
  • 185 Answers
37,004 is a printhead error, specifically that a Reservoir heater isn't drawing power from the power supply.
The printhead 650-4303-00 is expensive, unfortunately.
Whit
Item, Inc.
Posted on Aug 10, 2010
Xerox Phaser 8400 When I turn on the printer I get a "service Code" 37,004.40:62674. Can you advise me what the code means?
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir 0 Disconnect Reservoir 0 is not drawing the expected power from the supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Aug 24, 2011 | Xerox Phaser 8400 Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
8400 fault code
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
Sep 03, 2008 | Xerox Phaser 8400 Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
Phaser 8400
That is related to the memory or the entire electronics module.
There is no specific 11,009 codes that I can find.
I am basing this on the fact that the 11 codes are all based on the memories and ECT Module.
Nov 19, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
