Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do i sort error 5100?I have tried switching on and off but still not working.
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I con not use my printer Canon MP970. There is 5100 error. I have no idea how to fix it and why it happens.
hi,
please browse the following
www.printerproblemsolved.co.uk/I have problems with paper feed and cannot seems to be able to sort it out, I would like to open .... my printer come up with a error code 5100 canon mp970 .
May 28, 2011 | Canon MP970 Photo All-In-One InkJet...
Error 5100 appears on lcd when turning it on. How do I fix?
Try removing and reseating the ink cartridges. If that does not work try replacing the cartridges with genuine Canon ink cartridges. This should alleviate your issue as error 5100 is due to cartridge failure of some sort.
Mar 01, 2011 | Canon PIXMA MP610 InkJet Printer
When changing an ink cartridge on my i9900, the cartridge carrier suddenly began to move. Because the cartridge was only 1/2 half way out, the carrier got stuck for a second or so at the side of the slide...
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Jan 28, 2011 | Canon i9900 InkJet Photo Printer
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Aspire 5100 notebook error
look in device manager and you will find out what the conflict is, all you have to do is choose available port you want and change it that will sort the problem.
kind regards and please don't forget to rate us
Dec 01, 2008 | Acer Aspire 5100 Notebook
No display on acer 5100
hiiii ther
how r u ??
the beep u got is the motherboard diagnose for error in the video card
so even if u try an external screen it won't work
so if that ur VGA card is built in
u have to buy a new one
but 1st u should try this try to unhooke the card and clen it and hooke it back again and se what will happend if u get the beep again than it's dead my friend sorry
u take careand have fun
salammmmmmmm {bye in arabic}
Nov 20, 2008 | Acer Aspire 5100 Notebook
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Samsung sf-5100 Fax machine - no paper
Check inside the paper tray area to see if the paper sensor flag is dislodged. Otherwise it will be a board problem. Vacuum clean out any toner spill. Try a can of compressed air to blow any paper dust from any sensor. They will be the little black U shaped devices. Make sure the flafs move freely in and out of the sensors.
Jul 24, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
