Question about Samsung HLR5067WX 50" Rear Projection HDTV
Hdmi input doesn't work but component in works fine. When plugged into hdmi all you get is a blue screen
  • g_martin Dec 03, 2008
    I have the same problem. I have been using the HDMI port on a HDMI switch for over a year with no problems, a few nights ago the picture went out and I get the blue screen saying low or weak signal. I've tested for more than one source and used more than one HDMI cord so I'm confident it's the TV. I think it may be the DMD board and I am trying to find instructions for it's removal.
What are you attempting to use HDMI for? Sometimes you have to adjust the settings of the system that is using the HDMI connection. The tv needs to reset to HDMI
Posted on Apr 10, 2008
SOURCE:
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
Trying to hook up playstation 3 with either HDMI cable or RCA cable Neither one is producing anything? WHat could be the problem?
For the HDMI your TV input for that HDMI input may be skipped you should check and make sure that it is not greyed out and that you can select it. For the RCA.... You should make sure that you are hooking it up right. You either have composite cable 1 yellow video and a red and either white or black left and right audio to Yellow video and Red and white on the TV, or you have component which will be red green and blue all three will be for video and you will need 2 more rca jacks for audio. It matters where you plug the red green and blue cables as well. getting them backwards either won't work or will give you a tinted picture.
Additionally, make sure that your TV doesn't share inputs. Some TVs will have Video 1 and it will be composite RCA and HDMI and you can select which to use. if it sais HDMI one and Video one you should be fine there if both say video one or the like they are likely shared
Hope this helps!
Jun 25, 2011 | Sony PlayStationĀ® 3 (80GB) Console
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
My ps3 seems to b working fine but i cant see anything. no matter which tv i plug it into it says that there is no signal
Hi aztecruler12,
For you to be able to see a picture on the screen you need to make sure that you're on the right input. Inputs on your televsion depends on the cables that you are using. PS3 supports HDMI and Component Cable (Blue/Green/Red). If you're using HDMI Cable to connect the PS3 to your TV then you need to select HDMI Input and if you're using a Component Cable it should be Component Input. To change the input you need to use the original remote of your television. Look for Input or Source button and select the input depends on your cable.
Rate me if this helps so i can help others. Thanks for using Fixya.
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Nov 27, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
Samsung HLR5067WX 50" Rear Projection HDTV Logo
384 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
