Question about Aiwa XR-EM70 CD Shelf System
My system has swallowed a cassette, the tape is stuck & I can't get the drawer to open. It tries a few times (going 'click/clunk') & then gives up.Any thoughts please?
  • 21 Answers
Hi. Firts of all.. chances are that your unit needs to be cleaned or you used low quality cassettes in thr player. a tape has would itself around the capstan and pinch roller causing everything to jam up. you may need to open up the unit..seperate the cassette mechanism from the main chasis and take it apart delicately in order to get the tape out without breaking the door catch .. Use tweezers but do not mark or scratch the azimuth head...OR.. try it from the front and try to open the door with a fingernail in there..while pressing the eject...good luk. Trace Electronics Repair, Canada
Posted on May 07, 2010
How do I get a stuck cassette tape out of the Tascam 202 MKiii
With this kind of mechanism you need to open the deck up and assist the cam wheel by hand to get the eject block and heads to go down to the stop mode. This is the only way to get a tape out without destruction to both tape and machine. I have done it a few times. If you can not do it yourself, I am in the Chicago area as Skywave Tape Deck Repair. I can get the tape out.
Jul 02, 2015 | Tascam 202MKIII Dual Cassette Deck Studio...
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Detergent dispenser not opening
try taping on the lid a few times,it will be stuck tru to many detergent
Jul 26, 2012 | Dishwashers
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
I have a VCR tape stuck in an old machine is there a trick to getting it out? It doesn't release it from the internal mechanisms! want the movie back!
I've had this happen to me a few times. The only way I could get the tape out was to take the VCR apart and carefully pull the tape out of the mechanism and all the tape that had pulled out of the cassette into the machine had to be carefully rewound back into the cassette. The tape itself is usually folded into many folds - so the movie needs to be copied as soon as possible onto a new cassette; as it won't play too many times with all the folds before getting stuck again into the VCR.
There is a little button near the door on the side of cassette itself that will allow you to open the door and rewind the tape easier.
Sep 21, 2009 | Televison & Video
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Cassette tape stuck and door won't open.
Ruan, A temporary fix, is to leave the right side panel off, position your latex gloved hand into the back, of the drive, turn softly, with one finger, the drive wheel, and the unit will unlock. You can now remove the tape cassette. Make sure the cassette tape is very, tight prior to installing it..
To complete a repair, takes a while for full explanation. Regards fmauka...
Jan 06, 2008 | Aiwa NSX-A505 CD Shelf System
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Aiwa XR-EM70 CD Shelf System Logo
274 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
