Question about Sharp 19C140 19" TV
Sharp 19 inch 12v and 24v missing - Sharp 19C140 19" TV
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
How do I fix lcd tv skyworth 40E58 power problem
The command to generate the 12VDC; from the power supply should come from the main board. S the main board should be troubleshooted in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 17, 2015 | Skyworth SLC-1971A 19-inch 720p LCD TV/...
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks in...you risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with 12v...no risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
Sharp lc 60e88un shutdown the 24v from power board no 12v
to check for led eror vol_ channel+ hold and press power switch once andrelease only power switch triangle light should come on then release the vol and channel knobs if set comes on the leds defective in screen
Mar 02, 2012 | Sharp LC Televison & Video
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
The tv does not turn on . You can hear it click and click but never turns on
there is problem with your power board fet or drive ic faulty. Check voltage some one missing. like 12v,32v,5v,24v dc. Which voltage missing only same line.
Oct 18, 2010 | Samsung LN-T4665F 46 in. LCD Television
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota 65lb thrust 24v
Hello!
Your unit was desined to run on 24 Volts.
The control unit (electronics) will not run below 19 Volts (19 or 20, I can't remember) and the armature windings and magnets are designed for 24V as well. So, an easy answer is no your unit will not operate in 12volts.
Hope this helps out!
Mike
Sep 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Sharp 19C140 19" TV Logo
49 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
