Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Enable security on wireless network
My wireless network shows unsecurd. How do I enable security/
  • 4,281 Answers
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Posted on May 06, 2010
Lenovo Z70-80 problem with wifi (don't show). Please do you know why? Thanks for any answer
see p18 of the user guide, downloadable from Lenovo website for how do this in win 8.1 (selt other o/s presumably)
it says
Connecting to wireless LAN - - -- - - - -- - - -- - - - -- - - -- - - - -- - - - -- - - -- - - - -- - - - -- - - -- -
Enabling wireless connection
To enable wireless functions, do one of the following:
• Press F7 ( ) to disable the Airplane mode if the mode is enabled.
• Open the charms, and select Settings ? to open the Network
configuration page. Toggle the Airplane mode switch to Off.
Connecting to a wireless LAN
After wireless has been enabled, the computer will automatically scan for
available wireless networks and display them in the wireless LAN network
list. To connect to a wireless network, click the network name in the list, and
then click Connect.
Note: Some networks require a network security key or passphrase for connection. To
connect to one of those networks, ask the network administrator or the Internet
Service Provider (ISP) for the security key or passphrase.
Jan 15, 2016 | Lenovo Computers & Internet
FORGET THE PASSWORD
it should be written underneath the modem
Apr 07, 2014 | D-Link Wireless N Access Point Dap-1360 -...
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Linksys WCG200 Router
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Why won't it connect to the internet?
First, you will need to know the wireless settings (such as Wireless network name and Wireless security) on the wireless access-point or router.
Once you have those settings, use the WUSB54GSC wireless utility. It should show the wireless network name of your access-point. Just select the name and click connect then type the passphrase or wireless security key, if enabled.
Nov 15, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Crack wireless securty enable
ITS illegal, to crack passwords of secure enabled WIFI networks. go get your own wifi.
Jul 10, 2009 | Computers & Internet
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless
not sure what exactly you meant to ask but if you have security setup on your router and you would like to set it to unsecurded here are the steps:
1. go to the router: 192.168.2.1
2. enter your user and password - default user is "Admin", password "1234"
3. on the left side click on "Wireless" -> "Security settings"
4. in the first dropdown select "Disable"
if you don't remember the password to the router then you will have to reset it by pressing the small hole on the rounter itself for 10 second.
note that you will reset all the router's configurations back to the factory settings.
May 30, 2008 | Edimax BR-6216Mg Wireless Router...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
249 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
