Question about Vacuums
I have a hayward 1HP superpump with an Ao Smith UST 1102 motor on it. Last year I had a leak in the pump, and I believe I got some water in the bearings of the motor. Over the winter I replaced all the seals in the pump, and have no leaks this year, but the pump is sounding pretty loud since opening the pool this year. I have (2) fold question: (1)I can not find any information on the where I can find a replacement bearing for this pump. (2) I can not find a procedure on HOW to go about replacing the bearing on this pump.
  • trrhodes May 06, 2010
    I have a hayward 1HP superpump Model C48K2N143 Ser 8K93 with an AO Smith UST 1102 motor on it. Last year I had a leak in the pump, and I believe I got some water in the bearings of the motor. Over the winter I replaced all the seals in the pump, and have no leaks this year, but the pump is sounding pretty loud since opening the pool this year. I have (2) fold question: (1)I can not find any information on the where I can find a replacement bearing for this pump. (2) I can not find a procedure on HOW to go about replacing the bearing on this pump.
  • 10,865 Answers
I filled the bladder tank u[ with water and no water comes out and the flow gauge doesn& turn
Yes not pumping water out could be related to the belt not turning the pump. It also could be a bad pump or clogged lines.
Dec 21, 2014 | Bissell 2X Proheat 9200 rug cleaner
Black & Decker Steam Buster SV1000. Can't get to steam (or spray). Never used before but have had for several years. Nothing clogged. 50 water/50 vinegar in water reservoir. Vacuum works fine. Pump...
The impellar or your water pump is on its very last broken fin, time for a mew machine or the long hunt to find a replacement impellar
Nov 06, 2014 | Vacuums
I have a powersteamer and it does not spray water when I squeeze the trigger. The clean water tank is full, the cleaning solution is full and this is the same problem I had with my last Bissell steam...
Every line has an O Ring at each end. inspect each one by removing the O Ring for nicks and cracks. Lubricate the with Vaseline and reinstall if ok so they will hold the prime to pump and vacuum up Your leaking O rings will draw air causing your problem and did so on your last one most likely
Aug 07, 2011 | Bissell Vacuums
When the water sprays out leaves water lines on carpert . shouldn't the water spread out
http://www.youtube.com/watch?v=QBtWcC4gqjY
I found this solution on youtube. I believe the vacuum motor for the pump is not working and needs to be cleaned and oiled. See the video.
May 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a tetra tec ex700 which is leaking from the sides of the canister.sice last year i have had 3 replacements sent and all with the same fault.can you advise if its the valves leaking into the motor...
I thought i would share my problem as it is known now thatthis filter has leaking problems.
Mine started leaking every time i cleaned it or just switiched it off i triedeverything i could to stop it but i could not.
I found a write up about the leak on the net there was a fault in a large batchwere water would get into the head caseing
and force itself out down the sides of the filter.
well i found the number which is 02380606070 for tetra which is in germany andthey were very helpful and sent me the parts i needed free of charge clip_image001.gifclip_image002.gif
Filter is spot on now no leaking at all hope i help others if the problemshould happen
Sep 28, 2010 | Vacuums
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
May 29, 2009 | Bissell 1400 Little Green Pro Canister...
My Hoover will not turn on
there was probably a leak in the hose/piping near the pump in the vacuum that shorted out the motor. you will need a new motor for the vacuum. you will also need a new pump assembly. i strongly recommend that you also replace all the internal tubing and places where the pipes join.
Aug 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
I have a bissell 1698 powersteamer. i have already cleaned heater and completely cleaned all parts , checked the mix piston, checked belt. it will not shoot water or mix. the motor runs, it will ****...
Pump is probably bad. When you put the lid back down, did you put the piston on the bottom of the smart mix knob? Also the smart mix knob should be in the water only selection when the top is pushed all of the way down. Also sometimes the flow indictor cap can give you a problem with it leaking air.
Apr 13, 2008 | Vacuums
Vacuums Logo
367 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
