Question about Philips 20PT6441 20" TV
Trying to unlock hotel tv (philips)
I am staying in a hotel on and off for the next month and wanted to get my xbox 360 working if possible.
Following the advice from the link beliw :-
http://www.fixya.com/support/t924956-unlock_philips_hotel_tv_21ht3302_41
I entered the service code and the service menu popped up - however this appeared to disable all buttons on both the remote and the tv (with the exception of the power button).
I reported a faulty tv to reception and requested they move me...so I now have a working (but locked) tv.
Is there any way around this?
  • 56 Answers
SOURCE: How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Posted on Jul 05, 2009
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
SOURCE: how can i unlock philips hotel tv 21ht3302/41?
If you're looking to "unblock" the inputs, (for example; connecting a dvd or a xbox, ps, etc) it is possible to do it if the tv is a philips...just follow this instructions to access the menu:
Use the Digit 0 -9 buttons to press digits
319753 followed immediately by the mute
button. Note: Digit buttons 3,1,9,7,5,3
and the mute button must be pressed
successively within 20 seconds for the
TV setup menu to be activated.
Then you just need to create another channel, add the input (vga, svideo, avg, hdmi, etc...) and store the channel
Posted on Nov 07, 2008
SOURCE: help unlock child lock on tv.
The solution is so simple!
Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
Posted on May 31, 2009
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Posted on Apr 17, 2010
Unlock Philips model # 37HFL5581V/27
Hotel TVs use unique remote codes so guests will not steal the remotes. A universal remote is unlikely to contain the code.
Jul 27, 2016 | Philips Televison & Video
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
How to unlock AV on hotel tv philips HT5504/01Z?
mon tv mise en vielle apres toutes les 15 minutes
Aug 30, 2009 | Philips 20PT6441 20" TV
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
Keep telling me lost hdcp. It's been working. TV PHILIPS plasma
it sounds like your cable is going bad or your tv/360 might not be on a HD setting
Apr 27, 2009 | Video Game Consoles & Games
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
but recently
please...
Aug 14, 2008 | Philips 20PT6441 20" TV
I have a philips tv and a xbox 360. I cannot get the xbox to work with this tv. The xbox is pluged in to the tv and I know the yellow white red cords work because they work when i use the vcr. It was...
I guess when I moved the xbox i hit the swith for the hd and regular tv. It's on the back of the xbox next to the power cord plug in. I could hear sound but i couldnt see the screen. When I swithched it to TV the picture came on.
Jun 01, 2008 | Philips Televison & Video
Philips 20PT6441 20" TV Logo
298 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
