Question about HP vp6320 Multimedia Projector
I cannot adjust to get proper color mix, especially the red. I have Maybe I am missing something. Do you have any suggestions to get more red in the picture?
  • 144 Answers
Check the vga cable is not missing any pins,replace the vga.
Posted on May 08, 2010
I have a hitachi 50c20 tv and it has a red tint/hue across the whole screen
Are you using component cables into the TV? It sounds like one of the 3 video cables may have come out saturating the red colors. Check your cabling int he back of the TV, see if you remove 1 by one if that changes the colors. Each cable on its own should have a picture with either red green or blue colors. If any of them are missing the picture then the colors will get messed up when all 3 are plugged in. If you are not using component cables then check the color settings on your TV. Somewhere int he menu of the television you should have something like picture display settings that let you adjust the colors. Check and make sure that the reds are not over configured or the others are not set too low. You may also want to check that your source is proper as well. Check that other sources look okay or if it is with all different connectors/sources that the issue occurs on.
Oct 15, 2013 | Televison & Video
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My Vizio 32 inch HDTV picture colors are all off. I have tried to adjust the tint/colors but the overall picture colors are all off. It is as if some of the primary colors are missing.
Maybe if you are using component input wires, one is not inserted fully. Set color to max and put tint in the center, then flip channels and look for known solid colors items of red, blue and green. You can see when one is missing, as a mixed color will just look odd, but a true r,b or g will just not be there so to speak. Hopefully is might just be a feed wire in, but be careful, as too much pressure on insertion can crack a solder joint inside the set.
Nov 26, 2010 | Vizio L32 32 in. LCD HDTV
The color seems messed up on cable...like its missing red or something..however if i turn the xbox on the colors are perfectly fine...whats going on? ive tried to adjust the colors but that does seem to...
If you are using component cables (red-green-blue) for your cable hook-up you may have problems with the red one. Check to make sure it is inserted properly at both ends. Note that there is also a red-white pair for sound. This is not the red one in question.
Sep 10, 2010 | Mitsubishi WD-73735 Television
Color problems. last night instantly the color
2 things the cable could be faulty (unlikley)but worth a try
or your lamp is starting to fail
Jun 26, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
No red
the color red is a mix of two color. so run the cleaning tool on the printer
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
RCA D52W20 52' The images are fuzzy. The colors
the ITC222 convergence option missing repair kit at the following link will usually repair that. The kit has the parts and the CD with instructions
http://www.tvrepairworld.com/
Jul 20, 2009 | Televison & Video
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
HP vp6320 Multimedia Projector Logo
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
