Question about Sony VAIO VGC-LV110N PC Notebook
Vaio operating system not found.
Error message on startup reads: operating system not found. Have recovery cds but they aren't working because no partitions are found.
  • 979 Answers
Hello calimexdude1, hi, it looks like your hard drive is done for, but hold on, try first to format it, low level will do. download utilities from your hard disk maker's website. and re-setup OS.
Posted on May 06, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 101 Answers
First check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
My sony notebook PCG V 505 AX stopped booting with message "operating system not found". I took the help of the 3 system recovery CDs which came along the machine.While the first CD runs...
The problem seems to be in your cds. In this case, especially if the product is still in warranty, you can ask from Sony website if they will send you a new set of cds.
Aug 21, 2011 | Sony VAIO PCG-V505EX Notebook
Operating system not found.
Now, this is a real embarassing fact of Sony computers. The error can occur even in out of box peice. Reset BIOS to default values, check if the computer is booting to Windows in safe mode and restore if yes. You can acess the safe mode by pressing the F8 key. If the issue persists, perform a system recovery using the recovery partition. You can acess the recovery partition by pressing the F10 key at startup. Selcet the Restore C drive option top recovery computer to its factory settings. If you want to backup and important data from the hard disk, use the rescue data feature option from the VAIO Care recovery partition. I could provide you with a more precise and direct article link if provided with the exact operating system and model # information.
Jun 08, 2011 | Sony VAIO Notebook
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Sep 04, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Vaio sat survey not working
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Spilled water on keyboard of Sony VIAO VGN-FW250j and crashed HDD. Get system not found at startup. Replace HDD and get error:333 when loading recovery media kit. All hardware checks OK by Bestbuy geeks...
unfortunately water has a way of finding it's way into the circuit board, when it does it causes immeasurable damage, as parts of the circuit, and components that were not meant to get voltage are exposed to it, this generally ruins the machine's motherboard, with little chance of recovery. The HD may be OK as may be the DVD however anything electronic will generally be ruined,sorry. A recovery DVD is only good for SOFTWARE, problems... you have a hardware issue.
Mar 01, 2010 | Sony VAIO (PCWA-A200)
I have a Sony Vaio VGN-N130G. It crashed and I am trying to get it to reboot from the recovery disc but after the first disc starts the Complete C drive thing it stops and says ERROR 400 and can't...
Make sure that the operating System on the recovery CDs is the same as the one on your computer.
If you are trying to recover from a CD with Vista and your computer operating system is Win-XP that will not work.
Other Thing may be you had a hidden partition and some how you over written it or it is damaged.
check the hard disk partition stat.
Nov 27, 2009 | Sony VAIO VGN-N130G/W Notebook
Hi guys, I keep getting an error message that says: Stream reading error when I try to use the sony vaio recovery wizard. My computer is the sony vaio pcg-frv27 notebook. The first problem was that...
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
Mar 14, 2009 | Sony VAIO FRV27 Notebook
Vaio error message
This generally indicates a hard drive failure, but occasionally it's just an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or install, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Sony VAIO GRX550 Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
Sony VAIO VGC-LV110N PC Notebook Logo
244 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
