Water Heaters Logo
Posted on Dec 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a Ideal Standard E type Cf50 boiler. When the heating is on there isn't enough hot water for 2 showers and the water at the taps is just luke warm. When the heating is off there is plenty of hot water at the shower and the water temperature at the hot taps is unbelievably hot, scolding almost. Any ideas?
Paul Carew
Level 3:
  • Water Heaters Master 3,808 Answers
  • Posted on Dec 17, 2017
Paul Carew
Level 3:
Answers
3808
Questions
Helped
1300080
Points
10526
Check cylinder stat , if fitted check 3 way valve is fully open on hw side . Check water level in header tank
1 Related Answer
pipesster
Sean Lavelle
  • 21 Answers
  • Posted on Jan 25, 2010
SOURCE: The temperature in my shower is very luke warm
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
1helpful
We changed boilers to a combi boiler but kept the cylinder which is heated electrically for the shower. Can we heat the water in it from the combi boiler
You would have to have a indirect cylinder and motorized valves ,clyinder stat . It could be done you would need a heating company to check it all out .
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
2helpful
2answers
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
3helpful
2answers
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
