Question about Xerox CopyCentre C128 Black and White Copier
Reset the machine
Hi, I want to reset the whole machine and customize it the way our office wants it!
    President:
  • 2,072 Answers
Exactly what do you want to change?
No need to reset everything. You can change it item by item easier.
Posted on Mar 27, 2008
  • 2 more comments
  • Rick Kasper Mar 27, 2008
    I can send you any information you need to change the settings.
    if you want to reset the entire machine though here is the procedure.
    1. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
      The CE Mode - Password Entry screen will appear.
    2. Enter the Access Number 6789 and press Confirm.
      The colors on the display are reversed to indicate that UI Diagnostics mode is active.
    1. Access Diagnostic Routines.
      1. Enter UI Diagnostics (Entering UI Diagnostics in UI Diagnostic Mode).
      2. Access Diagnostic Routines (Accessing Diagnostic Routines in UI Diagnostic Mode).
    2. Select Maintenance/Diagnostics.
    3. Select Initialize NVM.
    4. Select the desired item, then press the Start button.
    5. After initialization is complete, use the data accumulated in Initial Actions to restore the machine to its previous configuration.
    Initial Actions
    • Disconnect any Foreign Interface devices.
    • Obtain all of the following information:
      • NVM value factory setting report (typically it is located in the Inner Cover pocket)
      • Any customer setting Auditron account from the system administrator
      • Any setting changes (specifically NVM settings) shown on the machine’s service log.
      • Any customer settings in the Tools mode.
Where is reset button
I'm not really sure what sort of equipment you're needing to reset, but on most office equipment the hard reset button is a pinhole on the back or side of the machine. You have to use a safety pin or a paper clip to depress it.
Sep 06, 2017 | Office Equipment & Supplies
Dyson reset button
DC25 doesn't have a reset button - if the brushbar isn't rotating, please follow the steps shown in the video below to check the cleaner head and brushbar for obstructions, then reset the machine.
Please note, the brushbar will never rotate when the machine is standing upright, so make sure you recline your DC25 into the vacuuming position before testing it.
You may also want to refer to our online Support guide:
http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 16, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
MY BROTHER MFC-8460N COPY MACHINE WILL ONLY COPY ONE PAGE AND SAYS THERE IS A JAM AND TO REMOVE THE DRUM AND CLOSE THE FRONT PANEL AND I DO THIS AND IT WILL WORK FOR ONE MORE PAGE. THERE IS NO PAPER JAM...
HI. Most likey the issue is with the Fuser. Just replaced a fuser on a printer that had the same issue. The pressure roller and sleeve need to be replaced on the fuser or just get a new fuser. Whole fuser assembly is avaiable online for $99 new.
Fuser for Brother HL5250DN DCP8060 MFC8460N MFC8660DN Printer LU139001K...
Nov 21, 2017 | Office Equipment & Supplies
When i plug thr machine in the power light does not light up. Is their a reset button.
Hi your shredder may have a power problem or the power cord may be bad and you can also try plug the shredder into another wall outlet.
Aug 03, 2010 | Office Depot Ativa CX10W Shredder
Hi, is there a way to Reset office 2010? I need...
If you wish to "reset" Outlook - close it and use the Mail shortcut in the Control panel to remove / delete your present account.
May 10, 2010 | Computers & Internet
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
How to return factory reset without admin authanticatioın?
function-7- then press the monitor key 4 times slowly-- then press start button [*] - should say service mode.. then press 6 then use the down arrow till you see shipment set. press start then press start -then you can reset the counters if you want . have fun
Jan 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
When the machine is plugged and turned on the whole screen becomes black
Some models have a reset button on the boiler, some have a fuse that can be replaced.
Jan 11, 2008 | Gaggia Syncrony Espresso Machine
Xerox CopyCentre C128 Black and White Copier Logo
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
