Question about Vacuums
I own a Panasonic ME-C4051.
I own a Panasonic MC-E4051. It would be ?Perfect? BUT?~ although the hose has fantastic suction when I use my vacuum in the upright position it has very little suction! What am I (not) doing?
    President:
  • 1,673 Answers
Check by the brush roll, the inlet may be clogged, also may be time to change the belt, they stretch after a while.
Posted on Mar 27, 2008
How do I improve suction of the Panasonic mc cl310 vacuum
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the hose and canister to make sure nothing is lodged in them. If nothing is there and it does not fix the problem, your issue could be related to your brush-roll. Check your brush-roll to make sure that nothing is interfering with it. If that does not solve the issue, the next area that should be checked is your vacuums filters. Filters should be replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement Panasonic vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Panasonic MCCL310 MC-CL310 MC CL310...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Need part number for hose alone for panasonic MCV9610
The following hose fits models MC-V9610, MC-V9620, MC-V9635, MC-V9647.
It can be found at: http://www.pasc.panasonic.com/epartr/PartsListChoice.asp?validate=1
AMC94P-GEZV004
Jan 08, 2011 | Panasonic Vacuums
I have a panasonic mc-ul975 vacuum that works great when working properly. the airflow through the canister seems to stops once the aero blast technology is done running which causes the vacuum to not...
Hi there. In Panasonic vacuums2.gif, there is a thermostat protection on the motor. It will automatically shut off the motor if there is no airflow through the motor. This is typically caused by a clogged hose. Typically, if your dust container is that full, there could be backup in the hose. Or the dust container being too full could also or otherwise be the problem. Check your hose for blockage, let the machine cool off, it should start up again
Aug 30, 2009 | Panasonic MC-UL975 Upright Vacuum
The suction isnt working
disconnect the hose where it goes into the base and see if you have suction there.if you don't then your intake hose is clogged.thats the hose that your long stretch hose connects to.take a coat hanger and bend the tip so the end is rounded.work it down into the intake hose at the bottom and try to push the clog out through the bottom.make sure your filters are clean and the bag isn't full. please leave feedback
May 05, 2009 | Panasonic MC-V5005 Bagged Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Panasonic mc-v6840 Low suction.Changed bag and cleaned hose blockage
Check the sole plate where the roller brush is. There may be an obstruction leading from the sole plate to the main dirt channel. Usually on many Panasonic uprights the main dirt channel is a removable bent plastic tube before it meets the bottom of the hose. Check to see if this isn't obstructed. ALso check your filters on the vacuum as sometimes a blocked filter means a lack of suction.
Jul 04, 2008 | Panasonic Vacuums
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Panasonic Stow'n'Go, model MC-V5481
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
Jul 10, 2007 | Panasonic MC-V7600 Bagless Upright...
No suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
May 02, 2007 | Panasonic MC-V7355 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
