Question about Canon CLC 1110 Copier
We have a problem error e020 03a0 what is
We have a problem error e020 03a0 what is this for
  • 59 Answers
Hi the problem is in the scanner lamp just cheq scanner lamp or drive bord
thanks
Posted on May 12, 2010
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
(fails to increase)
detention error
E100 Laser BD error
E220 Lamp ON error
plate read error
communication error
E302 Shading error
E606 HDD error
finisher)
communication error
E737 SDRAM error
E741 PCI bus error
(Rcon detection)
E744 Language error
(low voltage error)
[ADF]
E422 IPC error
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E531 Stapler motor
E577 Paddle motor
E590 Puncher motor
[Finisher-J1]
E531 Stapler motor
E577 Delivery motor
If nothing of these helps, send more specific description of problem.
Hope it helps
Jul 06, 2010 | Canon imageRUNNER 2200
My photocopy of canon ir3100f the give massage code error on screen i want solution
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E740 Abnormality of the Ethernet board
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Jun 26, 2010 | Canon iRC3100 Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon CLC 1110 Copier Logo
162 people viewed this question
old marine
old marine
