My girl friend has a RCA Scenium Model# HDLP50W151 She says that: You turn it on, then 5 minutes later, it turns off and totally reboots and starts at channel 002. 5 minutes later it does it again and again and again. What should she do?
  • 11,800 Answers
First of all make sure it's the tv's fault, not something else: check if it behaves the same whatever the source - cable or composite/s-video/DVI.
There can be a lot of thing causing that. The most obvious - the capacitors on the power source are failing - this should be checked by a professional , high voltage inside. The other main possibility is that there is something wrong with the controls - check that in the menu there isn't activated a shutdown option or a power saving one.
Posted on May 06, 2010
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
My tv made a pop noise and no has no picture just sound
Sounds like your bulb poped, They are easy to change, there should be an access panel on the back, here is a link to the bulb for your model.
http://www.allprojectorlamps.com/RCA-ScEnIUM-HDLP50W151-COMPLETE-LAMP-MODULE--HYBRID-BRAND_p_38779.html
Sep 15, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
My RCA Scenium HDLP50W151 TV has no picture. It
do you here a whining sound when you plug it up. when these units are first plug up there is a part called the color wheel that spins during boot process. if it doesnt reach speed then the lamp never fires. It is a motor and anything that moves evientally stops moving. it would have to be replace if you can get the part
Dec 10, 2009 | RCA Televison & Video
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Ramdon color changes
color in a dlp is controled by the color wheel.. this may be an indication of a pending color wheel failure. is the produceing a lound whining noise. this could be other problems but this is my first instinct on the symptoms given
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
Color wheel bad #212184
Approx $400 by an authorized RCA shop
Dec 31, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
