Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will not start
While riding the mower and cutting grass, I turned the key one click to the left (lights), the mower slowly died. Even after I bought a new battery for it, the mower has not started since. Like there is absolutely no noise or grinding or clicking sounds, electricity is not there. I found no loose wires. Pls help. Thank you.
  • 2,100 Answers
I have a feeling what happened was you shorted out the ignition switch, somehow. If you can get behind the switch without much trouble, try to jump the wires together 2 at a time just to see if it will jump the , lights, starter, ignition, one of the 3. or get a voltage tester, it will do the same thing. There is a fuse on there in the line, sits next to the battery. check it. Hope this helps,
Posted on May 06, 2010
I just bought an old John Deere 68 riding mower but it does not cut grass even though the blade spins when engaged. I made sure the blade was on correctly but it still doesn't cut. I noticed the pulley...
Are you sure it is the correct blade and when it is turning the sharp edge is on the leading side? A spinning blade will cut grass even if the blade is dull. Did you lower the deck to the correct level?
Jun 28, 2014 | John Deere 420,1020,2010,2020,2510,2520...
I just bought a used mtd sprinto. The previous owner seemed very genuine and said he hadn't used it for a while (a few months, I think). The mower is very clean all over and looks in good condition. The...
If there is an anti fire solinoid on the base of the float bowl you need to check it functions ok, unscrew it from the float bowl, switch the ignition on, the centre pin should retract fully into its housing, if not it will shut off the main jet in the carb and cause all sorts of problems.
Aug 10, 2013 | Mtd Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
I have an 07 craftsman 24 ohv, 42 " cut riding
Left blade is on backwards (liftng edge is contacting grass). Try reversing the blade on the left side.
Jun 15, 2012 | Garden
Why do cutting blades start slipping in heavy grass?
either the engine speed is to low or the belt is slipping how old is the belt is there a oil leak that got the belt wet with oil?
May 20, 2012 | Garden
I have a troy bilt riding mower. I put a new battery in it last summer. This yr., my son left the key in on positon when he got done cutting the grass. Naturally it killed the battery, I jump started the...
It may not be charging due to a bad connection to the battery or to the generator on the engine. The generator on the engine may be going or has gone bad.
I hope this helps.
Jul 27, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Will not start
there is usually a 20 amp fuse next to battery check to see if that is blown
Jun 28, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
207 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
