Question about Ricoh Aficio 2018D All-In-One Laser Printer
How to set the scanner feature of aficio 2018
    Scholar:
  • 92 Answers
As you did not specify which scanning type, I go for the most common.
Follow these steps:
  1. On the taskbar, click [Start], point to [All Programs], point to [SmartDeviceMonitor for Admin], and then click [SmartDeviceMonitor for Admin].
  2. Click the device to which you want to add destinations.
  3. On the [Tools] menu, click [Address Management Tool].
    Log in to the devihow to set the scanner feature of aficio 2018 - l_im02141_03.gif
  4. [Edit] menu, click [Add New User].
  5. Enter the name of the user in the [Name] box, and the name to display in the [Key Display] box on the control panel of the device. Here, we have entered the name Sam User and the key display name S.User.
    If you want to enter titles, select them from the [Title] boxes.
    (Titles can be used to divide users into logical groups. Title 1 is alphabetical from AB to XYZ, Title 2 is numerical from 1Title 3 is numerical from 1 to 5.)
    Next, click [OK].
  6. On the [Edit] menu, click [Apply Settings].
  7. When the message Are you sure you want to apply settings to the device? is displayed, click [Yes].
  8. On the [File] menu, click [Exit].
  9. On the [Group] menu, click [Exit].
Posted on May 06, 2010
Error sc 553
error SC533 is a problem in the fuser check/replace thermistors and check thermostat/fuse for broken circuits. then check the fuser if it is heating or hot then check the contact of the fuser and the machine there might be a loose contact on the fuser and connector of the machine. after checking it reset the machine by the way is this SC 533 for the aficio 2018 or other model?
Sep 16, 2011 | Ricoh Aficio 2018 Copier
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Jun 22, 2010 | Ricoh Aficio 2018 Copier
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2027 when scanning documents over 4 or 5 pages e-mail documents with no attachments, and pages of gibberish in the body of the e-mail. How do I fix this?
Try increasing the "max email size" -or turning it off all together.
I'm going by my own memory, so, you may have to do some browsing of settings, but I believe the setting is under: "User tools", "Scanner features", "send settings", (or some similar button under scanner features). There you should see a setting for Max. email size (or similar). The default is 2048kb.....try increasing it to whatever you want- maybe 4000-5000kb, and check the results.
Usually the machine will stop scanning when it reaches the max size, so I'm not sure if this is the problem, or if we are talking about very large files that actually exceed your emails capacity to allow an email of this size? How large are these files once scanned that you are talking about? What is your scanner's resolution set at? 200dpi is more than sufficient for text. You can check that at the same location as above only select "scan settings", "default settings". If resolution is set to 400 or 600 dpi the files will become MUCH larger than they need to be.
Hope this helps.
Feb 22, 2009 | Ricoh Aficio 2027 Black and White Copier
Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Oct 09, 2008 | Radio Shack Pro-2018 Scanner
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
473 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
