Question about Nvidia GeForce 7300 LE 256MB PCI Express Graphic Card
I have no red color - using geforce 6150 le. It's not the monitor (have tried changing monitors - problem remains. It's not the cable either. When I unplug the cable and just do the monitor selftest the colors are fine. I'm running Windows XP SP3 on a Dell Dimension C521.
  • poly22 May 06, 2010
    Thanks Techman. I was hoping it was something simple (read "cheap").
    Genius:
  • 1,112 Answers
Hi:
Replace the video card, the cards video output for the red video signal has failed.
Posted on May 06, 2010
  • 11,800 Answers
Simple test - use another cable, of another format (DVI instead of VGA). If it's the same then the card has died, replace it.
Hello, my video card is nvidia geforce 6150 le and the red color is gone, thank you for your help.
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
Aug 16, 2011 | HP Compaq Presario SR2020NX PC Desktop
Code purple
this is problem with VGA connectors pins if that is soled properly then the cable of monitor is damaged and need replacement.
if you check cable is fine then replace the Colore IC of monitor
May 11, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Geforce 7300 LE Secondary monitor problem
well you need to have both monitors plugged into the SAME graphics card and you need to play aroudn with your display properties. I know that when i did this in vista i click a dropdown box where the name of my monitor was and the selected my 2nd monitor and the number 2 highlighted and i could change it as i wanted. As for windows XP you may want to check here...
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
hope this takes care of the issue for you!
check out my site!! http://ctrlr4repair.webs.com
May 05, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
Monitor will not come on
Try to remove the wire connecting from the monitor to motherboard if there was a display in the monitor then no problem with your monitor. Try to check the battery in motherboard.
Aug 25, 2009 | HP Hewlett Packard Pavilion Slimline...
Video card/dual monitor set up
If the card has dual monitor dvi out puts your set if not your going to need a new card
Apr 03, 2009 | Computers & Internet
I want dual monitor for my PC
simply install another video card or get a card that has two outputs no pc will work with more than two video cards but the best setup is 1 on main board and one in the agp slot . or 1pci and 1 agp then enable them in your display settings :)
May 28, 2008 | Computers & Internet
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Nvidia GeForce 7300 LE 256MB PCI Express Graphic Card Logo
443 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
