a) Clean the printer
b) Print
Persistence: Probably sensor of the feeder has a problem.
Always good to restart everything, in case Windows plays tricks on you. ;)
You have to put darkness setting down on your driver.
2 chances: a) you have the headset with too much temperature due to darkness setting, or you are printing a particular color like metallic blue, gray or intense yellow that can make headset hotter.
b) When you say you have just a left side printed, i remembered customers that set the ribbon to 1/2 YMCKO, check it's not your case
Just see for a sensor located below feeder . Clean it with brush and blower. Also check for input setting in driver whether it is automatic feeding or manual.
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Before we start first things first, you DO have the color ribbon installed correct? If so, go to control panel, click Printers and faxes, right click the evolis printer icon, scroll down to properties, open it up, click the graphic tab, then select 6 panels ribbon (YMCKDK) that should do it since I had the same problem.
