Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Logo
Posted on May 06, 2010
The link http://192.168.1.1 is not working, how can I connect my router?
2answers
At first my d link dir 600 was working when i connect it to my wi tribe modem, after a few days the signal on my d links was lost but my wi tribe connection is still working when itry to connect aga
You will need to configure your router setting according to your ISP.
second, Contact your ISP if again and keep in mind that firmware uptodate. if problem is still remain use Linksys Home Support http://support.linksys.com/en-apac/support/linksys?icid=global-header-support-link and if use some other resources that will handle your router http://www.techsupportrouter.com/support-for-linksys-router.html
Hello, My D-Link DGL-4500 router won't work properly. The wireless portion will not work. I know the Username & Password. But no device I have will connect to it wirelessly. It'll connect...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Hello, I've had my D-Link router for about 5 years now. The model is WBR-1310. The connection worked fine up until today. I took off the connectivity between the router and my PC about 6 months ago,...
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
I'm trying to install a new 628 router. The wizard won't work and I have no clue what else to do. I have connected the router as per the limited instructions in the quick set up guide but it's not...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
1helpful
I have a d-link 615 router. The world light is red. I have tried resetting the router many times but still the red light. What to do next?
The router is now acting as a switch and not a router
The Internet line from the modem should go to the Wan-Internet connector of the router. If it doesn't then the router will not show an internet connection just Local connections
If that works as you have it setup, then I would suspect the "modem" you have is also a router.
Go to http://support.dlink.com and get the correct setup information for your router, click the "products" links for the manuals and updates etc. http://support.dlink.com/products/
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
2helpful
3answers
Have a windows xp desktop,and a apple macbook pro.what ROUTER
Buy a Wireless Router.
Select any of this following:
LinkSys
NETGEAR
Belkin
D-Link
1helpful
HOW DOES DL-524 WORKS AND WHAT ARE THE REQUIREMENTS FOR IT TO WORK?
First connect your cable from your interent service provider to d- link router .
Then configure your router settings .
For configure it you need to connect your router to computer with ethernet cable.
then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then configure as your internet service provider setting.
Top Trendware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
